Mg metro 1275 engine , 34,000 miles with light refresh last year . Fitted with Kent 276 s cam , new oil pump, Isky followers , uprated clutch (verteo) lightened flywheel , fully ported and polished head 18.5cc (11.5.1cr) chambers , bullet valve guides , 3 angle seats , mg metro 35.8mm valves . Light weight alloy timing cover back plate lightweight drilled clutch cover , s/gt close ratio gears with new drops , wood and picket alloy short shift , heat wrapped lcb , ported and port matched to turbo big gasket standard alloy inlet , ported and port matched hif44 carb red spring bda needle with ram trumpet and inclosed air filter , wood and picket alloy rocker cover and bolts , wasp hi torque starter .
PM ME AND I CAN TEXT YOU PHOTOS , thanks .
£650 in Norwich , norfolk , England .
