chaps chicks, i am planning to rustproof the underside of my van
its used daily but is basicly rust free, just some wire brushing needed
i have curse word-loads of cavity wax so obviously i'll squirt that in all the box sections/cavitys
the underside of my van is mostly the OE electrocoat finish & some stonechip
my options:
hammerite black underseal with added waxoyl-not a fan of undeseal really!!!
upol raptor loadbed paint which i have used before & i really rate it, its really chip resistant & is suprisingly thick-a very hard tough finish
dinitrol underbody WAX coating apparantly its very good???
my plan is to clean & coat the underside of my van in a really good coating to seal the underside from the elements
then inject all box sections with cavity wax-fookin loads of it basicly as i have lots
after injecting cavity wax a week or two later i will inject "fireproof/resistant" expanding foam into for instance the A posts/B posts/box sections/ panel stiffening sections/certain areas of the doors
expanding foam is used by alot of luxery car manufacterers as sound deadening
any advice for underbody rust proofing is the main dealeo at the moment though
cheers all ;D
my options:
cheers all ;D
