I have a very strange problem with my car its a Peugeot 106 1.6 xsi
during the winter there is no problems with this car at all but then when the weather hits over 30 degrees C the car will refuse to start
you can turn the key all you like but all you get is the display will light us as normal and there will be a small click and then nothing
if the car is left in the shade it will start fine but I live in a hot country where the weather is usually over 35 degrees and very little shade around and I keep getting stranded you can bump start the car and it will be ok you can put another battery on and it will make no difference and also jump starting the car of another battery makes no difference it still will not start when it is hot weather
any help would be greatly appreciated
I have had the car into several garages but it still persists if they leave it in the shade of the garage it will start so I still get charged for repairs that are not being carried out
