Feb 18, 2007 18:21:45 GMT
With a little help from my friends... Or friend... Well, its Sunday morning so bonnets are open and cars are getting even further from ever being in the road in Akku-land. Over two hours to get the air con compressor off the bleeder, its like some kind of thing they'd have on the Krypton factor. I have a Krypton factor of 0. But at theast the AC, the alternator, the accerssory braket and sundry other junk is removed from the front of the engine. Gawd knows whats going on here, but this is Simon, and he will shortly be regretting wearing a white baseball cap.... Anyway the intake manifold was easy enough to remove once we'd actually got to it. This involved removing more stuff like the EGR amplifier, some miscelanous pipes I hope weren't anything important and the distributor. Also had to pull on rocker cover whichis easy enough except for one comedy placed hold down bolt - thought we were going to have to remove the brake servo to get to it (in true Chrysler fashion!) but got it off in situ. Finally, manifold off! And then the crud!!!!I'm used to manky old engines. I wasn;t expecting it to be gleaming like a new pin in there but I was a little horrified at the level of cack in there.... Some of it was in bricks like coal. Here's one with my Motorola for size refference... Now this stuff has been building up in there for the last 22 years but now we've disturbed stuff and broken some of it loose, so its all got to come out or it will be clogging round the cam and oil pump drive before you can say "premature engine failure". Maybe thats on the black side but I know my luck these days... So pugged up all the ports, oilways and such with rags and been degreasing and scraping and all that and, yes, my neighbours probabyl think I have completely lost the plot as Simon and I have been hoovering out the engine... Does the trick though.... And then it got dark. Game over for another weekend.
Feb 18, 2007 18:42:32 GMT
Progress is progress! everybody needs a 'Simon' we'll have a decent amount of daylight to play with soon..... great work
Feb 18, 2007 19:12:58 GMT
Great work! Look forward to seeing it running
street
6.2 ft/lbs of talk
Feb 18, 2007 19:13:44 GMT
Good work! Very thorough, my lathargic side would probably have left that crapola in the engine and then regretted in later Its going to look rather pretty in there with the new manifold, carb and shiny filter, and go better too no doubt
Feb 18, 2007 19:14:02 GMT
Aye, Simon's been a lifesaver today. By the time I got the damn AC cmpressor off ('bout 12:30 or 1 PM) I was getting frustrated working on my own and would probably have jacked it in soon after. Simon turned up and we spent the rest of the afternoon on it and I was quite chilled out. Sometimes you just need someone there for moral support if nothing else.
Tell you what though I think I am defo farming out the work on the Olds to sort the trans...
Last Edit: Feb 18, 2007 19:15:25 GMT by akku
Feb 18, 2007 19:47:03 GMT
I've seen that sort of sludging (but not so big chunks) on the PCV outlet and firescreen on the old GT4 I had.
And yes, even though it was smaller, it really does feel like tarry coal particles.
Seth
Feb 18, 2007 19:50:22 GMT
Urrgh to the black stuff! Good progress at least Alistar if not yet to a running car stage. How much lighter will the front end be now
Feb 18, 2007 19:54:27 GMT
That looks to have gone a long long time between oil changes. We have an oil heater at work that supplies hot oil at 240 degrees celsius to preheat our mixers and that gets the same type of build up. Its a mare to get rid off.
Feb 18, 2007 19:59:13 GMT
Its evil gunky, crispy stuff. A consistancy all of its own. I think the problem is that the EGR and or PCV systems have not been working right for a while. The EGR valve was blocked up with it too, although of a more dry sooty consistancy there.
Lordy knows how long before its back on the road. The "needed" list is still growing faster than the "done" list. I'm up to my neck in other stuff, have no holidays left to take until April and its dark in the evenings...
Feb 18, 2007 21:20:24 GMT
Wow ! that looks like the stuff I dug out of my vans sump when I got it...... good work ! it'll be transformed when its back together.
Feb 18, 2007 21:40:34 GMT
I recently pulled the cam cover off of a GA14 (Nissan Sunny Engine) to find a very similar but worse looking scenario, the girl (my friends girlfriend) had not had an oil change since she got the car... years ago... SO, out game the toothbrushes etc and we spent a few hours scrubbing the curse word out of it. It looks good now, we didn't bother blocking anything up though (I had a GA14D sitting aside just incase all went pear shaped) runs mint now, no noises and i'm sure it must be lighter too! It certainly is horrifying to see coal like chunks in such places though!
Skyline: 1963 - 1973 - 1983 Sunny: 1982 450SLC: 1973 Navara: 1992 Gloria: 1992
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Feb 18, 2007 21:45:23 GMT
i pulled apart a rover v8 lump with that type of rubbish in it once. I just put each bit in the parts washer as it came apart I understand you cant do that though.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Feb 18, 2007 22:05:13 GMT
Si was all for pulling and tanking the motor. I don;t think he gets the concept of "quickly back on the road"
Feb 18, 2007 23:33:10 GMT
Si was all for pulling and tanking the motor. I don;t think he gets the concept of "quickly back on the road" if this so far on the CRY-sler is "quickly", then he may not be that far off lol
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Alistair vs The Chrysler Pt2tigran
@tigran
Club Retro Rides Member 142
Feb 18, 2007 23:38:22 GMT
Urgh the daimler lump is just as bad for that black shoite. Orrible evil stuff. Well done for being bothered to clean it all out. Keep at it!
bxer
Feb 19, 2007 11:08:34 GMT
Wow! I thought my BX had a lot of pipes under the bonnet At least the evenings are getting lighter now though ;D
