Copey
Apr 19, 2013 14:23:08 GMT
righty, i serviced the car and the plugs show that its runnin a little lean, i know where to adjust it (offside inner wing)
what i am after is which way to richen and which way to lean
cheers
RobinJI
Apr 19, 2013 22:03:40 GMT
I'm not sure specifically for your car, but I'm pretty certain leaning off should increase the revs at idle, while richening should slow it, so a quick tweak may give you an idea of which way you're going. (Assuming this is controlling the mixture at idle.)
Copey
Apr 20, 2013 18:59:37 GMT
Cheers, will have a bit of a play tomorrow and see what happens
