This is my brothers trusty T4 up for grabs.
It has the 1.9TDI engine He has owned it for the last 8 years, he has been using it daily in that time, it has been ultra reliable and has been well maintained.
Cam belt and water pump changed at 155000 miles
The bodywork is in really good condition for its age. The milage is currently showing 189k
The seats and the cab are in great condition, seat covers have been used since he had it, the drivers seat does have a small cigarette burn which was there when he bought it. The drivers bolster is showing signs of wear.
The engine runs sweet if not a little fast on tick over and it pulls well and blows no smoke at all, doesn't use any oil or water, there are no nasty noises, bumps or bangs, If well maintained these vans go on and on and on!
10 months MOT and is currently SORN
It is fitted with 18" Audi TT wheels, 4 good tyres, it has the has smoked rear light lenses and clear front indicators.
Both wind down windows are fitted with wind deflectors, there is also a front insect/wind deflector on the bonnet which can easily be removed if needs be.
The front has been lowered slightly, this can easily be changed either up or down as there is a nut that can be turned to adjust the ride height, a couple of lowering springs on the back would set it off a treat!
The rear door lock is broken, it is currently secured shut with a special van padlock.
This is a van ripe for a conversion, wether that be a day-van, camper or surf bus.
Viewing is highly recommended!
This has been a working van so please don't expect perfection.
The van is in Halesowen.... just minutes from J3 of the M5
PRIVATE PLATE NOT INCLUDED
Call Paul on 7970004784
