As i've just picked up my 6x10 alloys from the powdercoaters, my 6x13's won't be needed. In decent condition apart from some bleeding under the lacquer on the lips. they are in factory finish - silver centres with polished and lacquered lips.
fitted with 2 175/50 pirellis - done about 2000 miles, practically unworn and 2 older yokos about 40% worn with still lots of tread. valves are alloy stems
4x101" PCD, offset I think is +10 so ideal if you want to run a larger rim but without the bumpsteer of 7" rims. still plenty of dish is thats your thing......
when the wheels come off i'll post a load of pcis of each wheel/tyre. at the moment I only have this pic to upload so you get the idea.
I'm after £240, mainly because the lips are not kerbed and the pirellis are £70 each new.
cheers
Matt
cheers
Matt
