Run into a hitch with the standard..
its got spitfire hubs on the front to let me fit discs.. Today i spent fitting the other caliper mount and disc. Only to find that the caliper wont bolt up to the passenger side due to touching the hub. whereas a identical caliper will bolt up to the drivers side..
In the end i figured out that the hubs are different... But only sliightly..
Now.. Looking on ebay , Someone is selling a pair..And they are equally different from eachother..
www.ebay.co.uk/itm/Triumph-Spitfire-Front-Hub-Bearing-Set-T37-/221182644484?pt=Motors_Car_Truck_Parts_Accessories&hash=item337f835104
*groove running round between the studs
*looking from the back you can see small differences..
These add up to it being a few cm's further in (toward the car) and preventing fitment of the caliper..
Does anyone know why this would be? Or am i missing something ?
