make peugeot
model 106 inca diesel
miles 232K
engine size 1500cc
tax 08/2013
mot around the same as tax will check
v5 present and in my name
Right thought I would put the Peugeot on here to see if any one needs 4 months of super cheap driving
I have owned this little pug for almost a year now it dose 200+ miles a week and I put £20 in it on a sunday or monday has also taken me to summer set last year camping and around summer set
I change gear at 2000rpm and sit at 55~60 on the motor way I did track the fuel use for a little wile here >>> www.fuelly.com/driver/maxlee/106?fu=3021650
now covering the milage it has it has bangs and the odd creak fair bit of road noise etc every thing works but the hazard light switch the heater fan is noisey rust on the inner rear wheel artch etc radio and speakers will be coming out to go in the next car.
I fitted clocks in ity with a rev counter so temp gauge dosen't work (will if you put 2 pin sensor in) front drivers seat wont slid right forward I drive it 6ft 4 and my dad has used it 5ft 5 fine
has a privet plate on it might be worth some thing to some one,
I have smoked in it (window always open) and had the dog in it tools etc but I will give it a clean out paint work is french 90 day red so bonnet and roof is almost white in places dents in both rear 1/4's
engine dose not smoke even from cold might cough a little 1st thing for 1min if that but other wise I can't fault it.. its no race car
I have changed discs and pads, all filters (new oil filer in car as due)
passenger side drive shaft and maybe some other bits I can't remember
selling as I have to many cars
(you can see 3 on the drive in the back ground)
just after £200 takes it now needs a glow plug relay goes on ebay over weekend
car is in stubbington 4 miles from fareham town in hampshire
miles 232K
engine size 1500cc
tax 08/2013
