v8jim
One for the hot Rodders I think Is it possible to safely heat and bend the steering arms that bolt to the hubs on a 40s car?
I know hot rodders have been doing it for years and the early drop axles were made by heating and stretching stock ford axles
Having never done anything like it myself I was just looking for some advise
Max sig pic size: 80px
smurf
Dez to the retro ride phone
Laser cutting and cnc punching (up to 3mm stainless and ali, up to 6mm mild steel)
Mail me a dxf file and i'll get you a price Metal folding and custom fabrication service also available
unitybonez
Blowing Pintos
i think they hook to the spindle rather than the hub, unless I'm not gettin the question right, but if i am I'm positive you cando it.
Sent from my ouiji board.
v8jim
I am hoping for a reply from the RR guru of really amazing hot rods (metal sculptures)
v8jim
Yeah the spindle/upright not the hub but you knew what I trying to say lol
RobinJI
Prettysure Dez has covered it in either this thread or this one. (Unfortunately that's atill quite a bit to look through, but they're damn good threads anyway )
I've done it with Mk1 Escort and Sierra steering arms and never had a problem.
rld14
Yes it's fine... Assuming you do it right.
1) Heat arm until its cherry red to just orange, any hotter (yellow) or cooler is bad.
2) DO NOT QUENCH IT! Let it air cool ONLY.
3) always get the part magnafluxed BEFORE it goes on the car.
Follow them guidelines and you should be fine.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
rld14
Oh yeah,
Bend SLOWLY
Spread the heat around and heat it up slowly. Just heating a small section = bad idea.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
I've done the Escort ones on my Anglia. Heat evenly to cherry red with an oxy torch, bend it to the desired shape, then allow to cool slowly. Do not quench. Try not to concentrate the bend in one place or you risk necking the material. Make a little jig so both are the same.
v8jim
Thanks for the advise guys
Heating steering components results in an MOT fail. Well, at least it does if its obvious to tell....
Apr 10, 2013 12:24:11 GMT
Heating steering components results in an MOT fail. Well, at least it does if its obvious to tell.... paint
v8jim
Apr 10, 2013 18:02:44 GMT
Yes it would be an mot fail but I would paint them and it's 1949 so won't be getting one anyway
Apr 10, 2013 21:12:56 GMT
Yeah i understand that. Cant help but think though, its an MOT failure for a reason....
v8jim
Apr 10, 2013 21:19:16 GMT
Yeah but it apples to any steering or suspension component and a thin pressed componant is a bit different to a heavy forged one.
