Feb 14, 2007 16:56:10 GMT
OK.. what does everyone think to this?? Considering this as a possible project when I comes to the missu passing her driving test and taking the family car leaving me to get myself a toy! (not this particular LR, but a Series model none the less!) Still working out how this may be possible to do, but the photoshop is all the inspiration I need! also, the rattier the better I feel!
Last Edit: Feb 14, 2007 16:56:51 GMT by festerfly
I'm not saying I'm Batman, but have you ever seen me and Batman in the same room together?.........
And no, I'm not Ben Affleck!
Feb 14, 2007 17:18:00 GMT
What's it for?
Feb 14, 2007 17:33:03 GMT
the actual vehicle isnt so much in question.. more the severe lowering treatment it has received! here is the STD pic!
Peoples Opinion wanted...BenzBoy
@benzboy
Club Retro Rides Member 7
Feb 14, 2007 18:20:53 GMT
I don't have a pic of it, but that slammed '48 SWB Landy should be the first point of reference I reckon! Not so sure that it'd work on a 109" chassis though, looks-wise.
Feb 14, 2007 19:14:02 GMT
WARNING! EXTREME DIFFICULTY RATING!!
Have a look at how a LR is put together, ie. with the axles slung under the chassis. You will essentially have to go right back and fabricate a new chassis in these areas to lift the wheels into the body. However if you keep thestock axles etc, that's going to burger up your engine position.... do I need go on?
Feb 14, 2007 19:16:25 GMT
Oh in addition.... I suppose if you went to a coils set up (as opposed to leafs) you might be able to crank it down 'a bit', or even hi-jack the air system from an LSE RR... but that's still not going to make it 'very' low.
том
"If in doubt, flat out!"
Feb 14, 2007 19:17:02 GMT
take note:
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Feb 14, 2007 19:24:22 GMT
Great if you want to spend every weekend replacing busted propshafts, they just won't take working at that angle, exactly the same as if you jacked it 4"......the only way to do it would be to channel the body over the chassis, but then you'd end up having to fabricate a whole new interior/steering/pedals.....and you'd smash your skull on the roof every time you went over an expansion joint!!!
Would look ace, but there's a LOT of work.
RetroMat
Column Shifting!
Feb 14, 2007 19:30:19 GMT
could you just stick the Landy body on a different chassis like the hot rod one?
Anglia68
Powered By Boredom.
Feb 14, 2007 20:14:44 GMT
Buy a Landrover and a Scimiter and then swap bodies.You get to keep a cool low Landie and you get to sell a b*tching 4x4 Reliant. You know it makes sense. ;D
Feb 14, 2007 20:29:19 GMT
You cannot slam standard Series as the front diff would be in sump, prop joints not a problem unless you lift the suspension more than a couple of inches without rotating the nose of the diff, dropping it bring the axle and gearbox back in line but the would foul the crossmenbers aft of the gearbox. The one in Tom's post is a bitsa, Series 1 front panel, doors, seats and rear tub, Series 2 wings, bonnet, windcreen and front apron and scrach built bulkhead, the wheels are definately not Land Rover and I willing to bet the chassis frame isn't either. The only way lower a standard series alot is to fix the axles direct to the chassis, ride quality will be slightly worse.
"Educatio est omnium efficacissima forma rebellionis"
Feb 14, 2007 20:34:06 GMT
Buy a Landrover and a Scimiter and then swap bodies.You get to keep a cool low Landie and you get to sell a b*tching 4x4 Reliant. You know it makes sense. ;D YES!
sparko
Feb 14, 2007 20:34:36 GMT
Yup this has also been one of my dreams to slam a 90 series defender... it will be done though.... one day...
Odin
Feb 14, 2007 20:36:51 GMT
The hot rod one is actually a Rover underneath isn't it? A P6 or summat IIRC.
Feb 14, 2007 21:48:06 GMT
I -think- the rodded S1 is actually built on a Rover P3 ('48?) chassis.
bryn
Feb 14, 2007 22:10:20 GMT
I -think- the rodded S1 is actually built on a Rover P3 ('48?) chassis. Uhuh, Clive who owns it signed up on here but has never posted... For those that don't know it's the aforementioned chassis or summat very like that with matching front suspension, 3.9 V8 on LPG, narrowed Disco rear axle and a whole lot of fabrication... Any excuse for a pic
Odin
Feb 14, 2007 22:36:57 GMT
Ahh yes, I remember. That makes sense because then it would be pre-49.
I knew it was P-summat, I just bashed in the wrong number. ;D
B-8-D
down to one car!!
Feb 14, 2007 23:59:08 GMT
Buy a Landrover and a Scimiter and then swap bodies.You get to keep a cool low Landie and you get to sell a b*tching 4x4 Reliant. You know it makes sense. ;D IMO this is the best comment on this..... and i couldent agree more.... do it!!!! si
B-8-D
down to one car!!
take note: I think this is one of the truest HOT RODS about atm... I have heard this landyrod slated in many a forum (not mentioning them but it is NOT this one..) but it is more a rod than some plastic bodied "hotrod style" last year built jobbies... (IMO) I'm glad I said that.... in the open... now I can sleep... ;D si
Last Edit: Feb 15, 2007 11:01:30 GMT by B-8-D
Feb 15, 2007 10:17:36 GMT
must admit, not having a landy to hand right nw i cant go out and take measurements, but in theory it might be possible.
That S1 i have seena few times and chatted with the owner. Think he said it was P4 based. Must admit, that it is myinspiration for the project.
The Front diff/Engine sump issue isnt too bad as i might just lose 4WD altogether and fit IFS so that it wouldent be a problem... nex problem would be utilising another IFS setup to fit to it though! lol
Am going to see if i can get ahold of Series to do some measuring up! lol
