Kieran
Mar 22, 2013 23:51:32 GMT
Fitted a new clutch to the 1.4 k series engine in the mini.
Now when the clutch pedal is depressed, there is an intermittent grinding noise.
The clutch operates as it should, just this horrible grinding noise when the pedal is first depressed (goes awsy if you hold the pedal down) and when the biting point is reached the noise returns.
It's a 1.4 Rover Metro box mated to a late Rover 25 engine.
curse word release bearing?
Last Edit: Mar 23, 2013 9:41:54 GMT by Kieran
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Mar 23, 2013 17:10:41 GMT
The plate isn't in the wrong way round is it? if so the springs and gubbins will rub on the flywheel. It's usually fairly obvious if it's the wrong way round, but I've never seen a metro clutch.
Kieran
Mar 23, 2013 18:26:36 GMT
That was my first fear, but I don't think its possible, friction plate has a proud boss on one side so only goes one way.
Sorted itself out in the end, so I'm presuming it was just rust on the flywheel or pressure plate. This is the first time I'd tried it since fitting the clutch a few months ago.
Whoop!
Last Edit: Mar 23, 2013 18:27:42 GMT by Kieran
