v1xz
i'm retro
Mar 19, 2013 17:45:03 GMT
Afternoon all, my problem is this>>>>http://i87.photobucket.com/albums/k130/v1xz/Weller%20Wheels/894FE66C-3519-4B1E-8B1E-8E664F475EF9-62944-0000125E15E53EE1_zps8c507076.jpg
The wheels are far too wide for the car and now the car is scrapping the tyres, my question: Do i roll the arches? Can i roll the arch enough to make space for these thick wheels? Do i give up, sell up and buy smaller wheels???
1998 Merc E240 1997 BMW 728i 1998 VW Passat 2000 Kangoo 1999 Transit LWB 1999 Matiz SE 2001 Clio 1998 Golf GTi 1996 Ford Luton.... Retired.... Want a Motorbike... Got one... Yamaha WR125X... Missed RR sooo much... 1983 Porsche 944 1997 Celica 2000 Clio 1993 MR2 1992 MR2T 1989 325i Touring
Mar 19, 2013 17:57:15 GMT
lower profile tyres and bolt on arches
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Mar 19, 2013 18:21:36 GMT
You'll never roll them enogh to get them boots underneath. Maybe a slight pull, roll arches flat and way narrower tyres with a big stretch and you'd get away with it. The best options are; A: as per slacker, bolt on arches B: smaller wheels!
v1xz
i'm retro
Mar 19, 2013 18:48:48 GMT
As it stands, the tyres that were on we're 185/70. I managed to get them swapped for 175/65. I did originally ask for 165/60 but the tyre guy said it won't fit.
Mar 19, 2013 19:08:12 GMT
Wow, this has to be one of the coolest Matiz' I've seen! As for wheels, they're small in diameter already, it's just the width and tire size holding you back. Lower profile tires, a little camber (if possible) and some arch work or bolt ons should sort it
Mar 19, 2013 20:38:42 GMT
I always wanted to do this to the one I had! I assume they're 14's? 13's would work better IMO, and it's easier to get skinnier tyres - I know a supplier who does down to 145/80/13!
I'd suggest skinnier tyres (165 will definitely go on) and bolt on arches. Or just bolt on arches! Matiz's aren't worth much, so you might as well cut the arches under the bolt on arches too, so you can lower it properly.
The journey of 1000 miles starts with a single coffee.
I don't like coffee!
Mar 19, 2013 21:58:06 GMT
Bashy bashy roll them arches! Stretched rubber and super roll should get them to fit.. as above Matiz isn't worth millions so don't be scared to try
v1xz
i'm retro
The wheels are 13" Rims, ill look into camber shims as I'm sure i saw some on ebay. in regards to tyres, if i went to a different tyre place, these tyres that are on the rims are virtually new. Would they take these in as part ex??? As for lowering it, i think thats out the question. I have many speed humps in my area, very horrid single lumps. Plus its the wifes car which she takes the kids around in, i didnt really want to do anything too drastic to it!!! Where do i find bolt on arches?
g40jon
if you are crafty you could fit some bolt on arches or even weld some arches on, so the arch sits lower than std, thus reducing the arch gap and giving the impression of being lower than it actually is. kinda like body dropping, but on the cheap! I don't really see the point in fitting tyres that are too narrow for the wheel and running camber to tilt the wheel under the arch, it looks curse word (to me), it won't do much for the handling and it seems a lot of effort when you could have just fitted a narrower wheel in the first place. You might aswell make the wider wheels fit properly and enjoy the full benifits of them imo! As for pxing the tyres, i cant see many tyre places would be willing to, as they won't know the history of the tyre and they will struggle to sell them on, due to liability issues. Most tyre place won't even fit new tyres if they aren't supplied by them. (they claim it is due to liability, but the real reason is that they make most of their money on supplying the tyre)
Mar 20, 2013 12:52:43 GMT
v1xz
i'm retro
Mar 20, 2013 15:12:19 GMT
Thanks for the info, spoke to Tom and he recons 165/70 wil fit so i might give it a try. very Very cheap he gave but I'm gonna go back to the tyre place i got these from and ask him to swap them.
