Mar 15, 2013 19:47:34 GMT
Hello boys and girls I have a slightly mystifying problem.
After driving home from work today, I was pulling into my estate and I heard a loud clunk and noticed that the clutch pedal had suddenly become much easier to push down.
Any ideas why this might be and is it serious? I drive a 1993 MX5 1.6.
I have done a little bit of research and it seems that the master cylinder for the clutch could be to blame.
Thanks in advance
Well, that's won me over. * abandons logic*
Mar 15, 2013 20:35:45 GMT
Just been out for a short drive and noticed a slight whine when accelerating in 2nd if that gives anyone some more ideas
Kieran
Mar 15, 2013 20:35:55 GMT
Pedal return spring broke?
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Mar 16, 2013 17:19:25 GMT
Now that is an interesting question, I will check
Mar 19, 2013 12:28:26 GMT
Some years ago I the diaphragm spring in the pressure plate break, it gave the same lighter pedal, does the clutch slip? As the spring's broke it's not got the same clamping force anymore.
Jonathan.
bortaf
Mar 19, 2013 12:56:28 GMT
You can usually tell if a cover spring has gone by sidestepping the clutch, it will usially slip slightly and give a nice smotth take off and no wheelspin? you really need to have tried the same treatment before the change to notice though
R.I.P photobucket
