Triumph Estate to do list: 1. Remove Rover V8 - done 2. chop, weld, spray - ongoing, need motivation 3. drop in RB25 4. burn rubber
spacekadett
F*cking take that Hans Brrix!!
Looks like a 38 DGAS to me. Came as standard on 3.0 Capris and the like, but I have seen them adapted onto Rovers. Anyway, if you look round the base of the carb there should be a part / model no. like that there
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
yeah, i would say 38 dgas too, is that a custom manifold its on or a butchered rover one? Got a standard twin carb setup for one if you wanna do a swap
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Mr K
looks dgas to me. you can get a complete one for not too much cash, unless the choke butterflys are out to improve performance, not realy much cop on a road car though.
yep 38dgas usually found on 3ltr capris granadas (or it could be a 40 idf of a scimiter 3 ltr ) if the chokes open one then the other its a 38 if they open at the same time its a 40
i was going to say a dgas, never used one & don't understand them but i'm an su lad
Mini 998cc grp bonnet & boot, lightend shell, 6-point cage, soon to have a turbo on the 998 engine (t2 frm a r5gt) rs turbo intercooler, hoping to get 120ish bhp?
father is building a Mini Van 1330, 45 weber, 100bhp@wheels
'RIP' 1.8 Metro GTi, 15.23 1/4mile
GS escorts has them in widnes for £80...
nice carb.
Thanks for all the info guys, I had it in my mind it was a 38 DGAS for some reason, i'll check it out properly tomorrow in the light t0o see if i can see any more distinguishing marks. The manifold is a butchered Rover one, it just has a mounting plate welded to it. No swap needed thanks as i'm getting rid of the Rover engine. I have a set of rough SU's but they have some bits missing so they won't work. I have a new 390 Holley and Edelbrock manifold that i bought to go on the RV8 in the Triumph but now I have the small block chevy its nowhere near big enough so its all going on ebay.
you might have found it hard to start as it has no choke flaps.
did you ever try pumping the pedal a few times before starting?
Mr K
yep 38dgas usually found on 3ltr capris granadas (or it could be a 40 idf of a scimiter 3 ltr ) if the chokes open one then the other its a 38 if they open at the same time its a 40 naa scimitars got the same 38 dgas as all the others 3 litre essex powered wagons of the 70s, the 40idf is a dcoe standing on end bassically, stage one essex engines for the 40DF15 as used in capri 3.1s and thats a few of the big tuning companies.
B-8-D
down to one car!!
BLIMEY!! ;D i remember that....... that was one of the first webber adapted rover manifolds I MADE.!! yes it is a webber dgas... a triumph estate in green if i remember correctly a friends car.... is that the one? if so it really is a small world!! si
I'm going to name it Dave.
cortinadale
luvvly jubbly!!!!
yep 38dgas usually found on 3ltr capris granadas (or it could be a 40 idf of a scimiter 3 ltr ) if the chokes open one then the other its a 38 if they open at the same time its a 40 only the 32/36 opens one befor the other(4 cyl) all v6 carbs open at the same time or else you would be starving one side of fuel
We learned from an early age that...people who change signatures suck balls ;-) 1978 Cortina 2.3 ghia
Feb 10, 2007 21:12:42 GMT
Black V8driver, yes thats the car. bought it off a guy in Somerset i think. had it trailered up here blind and wished i had seen it in the flesh first, pictures can be so flattering. anyway, no use crying over spilled milk. I have some pictures on this site somewhere, if you search for them there are a few. i sure would be interested in hearing more about the car if you can tell me anything. its getting a blown small block chevy fitted to it as the rover wasn't enough, not that i even drove it like that, i just got carried away (the story of my life )
