Got a set of 4 renault 5 turbo alloys, two of which are a ghey yellow colour the other two are standard metal colour, cat (the other half) wants them russell spangly black (trademark) will they fit on her mk 3 polo without much hassle and will paint take to powder coating?
also why are 3 of the alloys made in france and the one of the yellow ones made in italy?
Ta in advance
Mike
East Midlands
They will be 4x100, same as the polo, dunno bout centre bore tho, best idea is to try them, see if they go on ok. Sure i've heard someone on here mention puttin renner wheels on a Golf before. One of the alloys might be a repro? If they all look the same, and are the same width, i wouldnt worry about it.
the one with the least corrosion (most powder coating) is the italian one - from that era i would have thought it would have dissolved by now!
centre bore is 60.1 mm being one of the biggest along the manufacturers , so you will have some slack on the hub i guess which is not a problem . you can use spacers if you want a tidy job .
i would not bother with where they were made as long as all dimensions are the same .
VW hub centric is 57.1 so you will need some rings
VW hub centric is 57.1 so you will need some rings where would i find such things of science?
Spigot rings...
Man, I love that word...Spigot...Spig...ot.
*n
wheel shops speedshack etc...
most aftermarket wheel shops will sell them . just tell them you are fitting renault wheels on a wv hub
