Nov 18, 2019 18:22:37 GMT
More progress as the car is now up in the air to get the exhausts sorted. However whilst doing that, I also swapped batteries and attempted to start the engine again. Then I found the centre carbs slightly seized...got that sorted and lost the sparks, got that sorted and jammed the starter....got that sorted and finally the engine briefly coughed into life again! Now I am having to get a bit more clearance for the rearmost carbs and trumpets.
Nov 19, 2019 17:09:43 GMT
I've had a short session today and have been able to split one of the exhaust pipes. I realised that, on the donor XJ6, the silencer is at the front near the engine - hence the curved manifold pipe and I will have mine at the back. So I will need to reverse the silencer, relative to the long pipe, to get the correct flow direction (not sure if it matters, but better to keep it, sort of, as designed). I also remembered that the section of "Y" tubing actually came from the original "Super B" in 1990.....
Nov 20, 2019 18:34:07 GMT
Another little bit of time to have a grovel under the car to try exhaust positioning. ....and "yes" I have managed to lose my other axle stand!
Last Edit: Nov 20, 2019 18:36:32 GMT by flyingphil
Nov 21, 2019 15:24:12 GMT
Eek careful crawling around under concrete blocks! I've known them to crumble surprisingly easily if you end up with pressure points in the wrong place. Looking great otherwise though
Nov 21, 2019 23:02:19 GMT
Thanks Biturbo, the car is well supported on the other three corners and the block is well cushioned. I have now got the silencer in a reasonable position, made clearance around the rear carbs and started to consider the last water connection to the radiator.
Nov 22, 2019 16:09:25 GMT
A nice piece of angled Aluminium tube should do the trick, except that Marton Welding have now moved and it is the weekend, so I cannot get it welded yet....
Nov 22, 2019 18:31:21 GMT
A new welding firm has been found and they have the tube, so progress is being maintained.
Nov 25, 2019 10:07:02 GMT
As I had been metal bashing to get the clearance around the back carbs, I have now been able to get the end ram pipes actually bolted in position, here is a picture to prove it....
Nov 25, 2019 13:05:25 GMT
here is a picture to prove it... As if we'd ever doubt you!
here is a picture to prove it... As if we'd ever doubt you! Thanks for your faith George..... In other news I have been working inside the car to actually get the interior panels attached, as they have been stacked around the garage for too long!
Nov 26, 2019 17:43:59 GMT
More fixing work on the panels inside, next I will be working to fill the gaps and spaces. I have also tried the seats again and they are just too big, so if anybody wants to buy a pair of light Lotus high back seats post/PM on here. There is a picture of the seats on P 18 (6th June 2016)
Nov 27, 2019 16:18:41 GMT
I had a very welcome call today from the Aluminium welder...... An excellent job - reasonable price and prompt service, so many thanks to....
Nov 29, 2019 12:18:21 GMT
I have cut up a bit of rubber tube and had a quick trial fit and it all looks good for the radiator bottom connection.
Dec 22, 2019 16:39:05 GMT
As might be suspected progress has slowed to a crawl with the cold and wet weather....however I just popped out to show some festive spirit and shine some light on the MeGa B. Merry Christmas and Happy New Year to all.
Dec 23, 2019 17:00:13 GMT
For those who love trumpets at Christmas...
Dec 23, 2019 19:57:48 GMT
You can get a similar effect with bad plug leads. Added benefit is that they flash when you crank the motor.
Dec 23, 2019 22:56:47 GMT
Darkspeed
Club RR Member Number: 39
Pro Jag "MeGa B" GT V12Darkspeed
@darkspeed
Club Retro Rides Member 39
Dec 24, 2019 11:55:08 GMT
Eleven pipers piping - Not another bloody misfire......
Feb 15, 2020 12:34:50 GMT
Well 8 weeks with not a lot happening, I thought that I would venture out into the cold damp garage in-between storms and have a tidy up. Another picture of the inside panelling just to show how much more needs doing.....I really need to get on with it!!
vulgalour
Club RR Member Number: 146
Pro Jag "MeGa B" GT V12vulgalour
@vulgalour
Club Retro Rides Member 146
Feb 15, 2020 14:12:44 GMT
Lots to do and also lots done. You'll have it done in no time when you get the chance to get stuck in on it.
