Another little job has been to sort out the steering wheel. I had bought a small "Mountney" wheel at the NEC last year "On Spec". I found an old boss in my spares stash but the O.D. of the boss was the I.D. of the wheel........ - the earlier picture of the wheel in place was just a precarious balance job! So I have now cut out three small aluminium tabs out of thick sheet and these bolt onto the hub and the wheel bolts onto the tabs. The spline was slightly smaller than the column spline but with a bit of careful filing and broaching in situ it is all good.
Nov 11, 2015 23:05:28 GMT
Last Edit: Nov 11, 2015 23:05:58 GMT by flyingphil
Nov 13, 2015 18:49:12 GMT
More work on the dashboard - cutting out the clear plastic cover for the speedo and revcounter Then filing and fitting......... I also made a frame to attach to the back of the dashboard around the steering column It is then welded to the chassis rails The bodyshell can be lifted at the front with the dashboard/steering still in place.
I've also started to look at brakes or more particularly the pedal/servo section. I have an XJ 6 and the XJ-S parts so will see how one or the other can be used
trev87
Nov 14, 2015 21:29:05 GMT
Wow I have just spent the last hour reading through this. Such great workmanship. I wish I had the level of skill to even think about this. It's going to sound truly amazing when you fire it up. Well done on building such a great car
Nov 17, 2015 15:30:23 GMT
Thanks Trev - glad that you are enjoying the build. I have tried the other servo in place but the pedal is a bit close to the exhaust and I think it might be "over servoed" with the lighter weight and much smaller front discs so I might try using the MG twin master set up without the clutch pedal.
Nov 17, 2015 16:35:21 GMT
Anyway I have been playing with the MG pedals and reversed them to put the unit on the floor( - which I did on the original "Super B"). I have also been cutting exhaust bends.......
smeden
"Full throttle until you see God,then shift to second"
Nice work on the exhaust :-)
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
adam73bgt
Club RR Member Number: 58
Pro Jag "MeGa B" GT V12adam73bgt
@adam73bgt
Club Retro Rides Member 58
Great work! looks like you're making good progress
Nov 18, 2015 17:01:04 GMT
Thanks Smeden and Adam Some more welding - and sawing - and angle grinding - and filing ...... .........and now I have a reasonable exhaust on one side (it should be much better than the ugly old cast iron one at least!)
Frankenhealey
Club RR Member Number: 15
Pro Jag "MeGa B" GT V12Frankenhealey
@frankenhealey
Club Retro Rides Member 15
Nov 18, 2015 17:05:43 GMT
I'm not envying you setting up those 6 carbs
Nov 19, 2015 17:27:25 GMT
I'm not envying you setting up those 6 carbs It will be interesting! By way of a change today I revisited the inlet system (- obviously inspired by you Ian!). All the manifolds have been smoothed inside and tidied on the outside. Then they were bolted to the heads and the carbs loosely bolted in place. One carb will need shaped, thick, gaskets, as the welding had tilted the stubs. Then I put the radiator in place and the wings back on. The next problem area will be the water pump outlet to radiator - the outlet points down and slightly back - and the steering rack is nicely in the way. It would be good if the outlet on three bolts could be rotated 120 degrees - but the three bolts are isosceles not equilateral!!! Anyway looking at the grille - and the radiator showing underneath it, I thought about the front end treatment - the original "Super B" had a sheet aluminium air dam with small lip. (It now has a fibreglass Sebring style). I thought a more modern approach might be a larger deeper grille - then I remembered I had bought my newer MG grille.......... It is just playing around but I think it may work?
Nov 20, 2015 10:14:33 GMT
I'm not envying you setting up those 6 carbs You could always flog him one of your turbines for forced induction? It is just playing around but I think it may work? Got a real Dodge Ram thing about that. Really enjoying the stuff going into this by the way.
Frankenhealey
@frankenhealey
Nov 20, 2015 11:24:53 GMT
I'm not envying you setting up those 6 carbs You could always flog him one of your turbines for forced induction? George, it would be the supercharger from HELL! If the SpridJET turbine blower can start the mighty Olympus engines on a Vulcan then Phil would need to add a few more V12's to take advantage of the available puff. I am really loving that mean-looking double MGB grille for some reason.
Thanks George and Frankenhealey I think the double grille idea is worth investigating further with sheet aluminium curved ends wrapping round the lower edges of the wings.
Nov 24, 2015 17:01:30 GMT
Lower front corners now roughed out and in place...... I need to swop the upper and lower grilles then remove the lower MG badge, I might also try blacking out the central horizontal bright bars?
Dec 11, 2015 17:38:56 GMT
This project has been going slowly so I think I need to set a target of getting it running by............ Christmas not finished but running! A fuel cell and pipework have now been ordered!
Last Edit: Dec 11, 2015 17:41:28 GMT by flyingphil
trev87
Dec 12, 2015 22:37:22 GMT
keep checking up on this and cant wait for more updates!
Dec 14, 2015 21:21:11 GMT
Thanks Trev87 Here you go - Progress - The two front grilles have been swopped and the older - now lower grille, has been split to remove the centre vertical bar with its integral MG shield. The water outlet casting has been cut and will be re welded with the outlet at a much better angle for the radiator. I also put a battery to the starter and it only "Clicked" but I'm not sure if there is some sort of inhibitor tied into the automatic transmission??
I like the idea of the double grill. Keen to see it roughed up on the car. As for the starter, how many wires does it have coming off of it? That would be an easy indicator as to whether you need to earth/short out something to get it to roll over?
