Right, it's stupid o'clock in the morning and I can't sleep because my brain is working overtime on build ideas. I've been scribbling ideas down on a note pad along with sketches on what I could do with a Citroen 2cv I have stripped in a friends yard. I prob should worry AFTER I've paid for it and got it home but I can't, I've toyed with 4x4 (but ill have that in my daily) or mounting the power plant in the back. Then I figured why not see if I can find a donor to plonk the shell onto?
So, I need ideas! The wheelbase required is 2.40m/94.5in. I've found a few odds and sods thanks to a quick google search, anything spring to your clever minds? Cheers, Chris
What about a 2CV Sahara replica ?
Feb 28, 2013 10:00:28 GMT
Yup beetle is the same, been done on a Dyane though, kind of done the Sahara thing already in the 2cv based kit car that I'm going to get my grubby nuts on soon.
Last Edit: Feb 28, 2013 10:02:18 GMT by rebel2cv
Feb 28, 2013 12:24:51 GMT
Land Rover 90 has an actual wheelbase of 93"
Paul H
Copey
Feb 28, 2013 12:45:42 GMT
2nd gen MR2? mid engined 2CV would be cool the 2nd gen MR2 wheel base is 94.5"
Last Edit: Feb 28, 2013 12:46:32 GMT by Copey
Bufort
Feb 28, 2013 13:53:31 GMT
what would be the point of putting a 2cv shell onto a beetle chassis? its not like you're having a nice reliable modern base and a nice classic looking body (such as the mini clubman estate on an MX5 chassis).
'06 Buell XB9 Lightning
'86 Ford Capri
and a billion other bikes covering all disciplines.
Feb 28, 2013 21:07:33 GMT
I believe a Samurai LWB and are Vitara are around 240cm.
Caterham/Locost/Westfield are 236cm'ish
Click picture for more
Feb 28, 2013 22:29:46 GMT
Some good ideas here, beetle like I say has been done In a Dyane anyway, land rover 90 has been done with a 2cv van but I like the idea, mr2 sounds dangerous and is top of my list..
Feb 28, 2013 23:10:06 GMT
Used to be a triumph vitesse chassis under a 2cv body, looked good and I assume went pretty well.
If you are thinking outside the box, then how about thinking a bit further out. If it is putting the 2CV body onto something with more power, then pick almost anything that can use wheels the rolling radius of a stock 2CV and 'simply' cut and shorten/lengthen the floor pan to suit. You are either going to use something with a chassis (limited to largely classics) or weld in your own roll cage/out riggers. My money if I wanted a jaw dropper 2CV, is build a full roll cage with mounts for the new suspension/transmission to link to. The wheel base is an 'easy' fix, it is the track that might be a little tougher nut to crack.
Ian Supersport900 Imp
Unless you find something with a separate chassis that gives you the required wheelbase, you're looking at Frankensteining on a unitary chassis. This requires BIVA. There. I've said it. And if you're Frankensteining, what's to stop you shortening the floorpan of your chosen donor?
Dez
Club RR Member Number: 34
WheelbaseDez
@dez
Club Retro Rides Member 34
scimmy chass is close enough, 96", 2cv wheel arches are plenty big enough to loose an inch each end.
froggy
I saw an mgf with a 2cv body on top of it that looked like it went together well .
