Hi guys,
As a few of you know i have been doing banded steels for a little while now, i have plenty of sets out there being used,
Basically I banded a set of mondeo wheels for a guy, they were not 100% airtight and the guy didn't seal them as instructed, he instead took them to a place to weld them up, which has been done, cut a long story short i have ended up with the wheels, they were never painted as the guy was going for a rat look,
I cant guarantee how well the two which were re-welded will balance, or their airtightness so i would recommend sealing them with z-poxey or similar anyway, although the weld is big its big all the way around so should still balance up ok.
Obviously you buy / run them at your own risk,
They are 16x10 , 5x108 but can check this,
not really sure what they are worth, so say £80 but I'm open to offers
either organise your own courier, or can be collected from Chelmsford or Coventry.
Note picture shows worst bit of welding on re-welded wheel.
Cheers
Ant
07854747675
Cheers
Ant
07854747675
