phatphord
Scorpilow
Thanks to James in the past for his help, but my laptop has been re-formatted and I've lost his spreadsheet..anyway,I'm looking to turbo one of my bikes and would appreciate any turbo recommendations. Its a 500 twin with a rev ceiling of 12k rpm. I am anticipating using an S.U carb to feed it. Am i better heading for a blow through or suck through set up? Should I also look at an additional oil pump? Sorry for all the questions. Cheers
1994 Ford Scorpio Lowrider um...and some bikes...
blow through for sure, get an HIF44 SU or some bike carbs.
I recon a T25 would supply the required flow at 20psi of boost too.
Run that suka on thinners and petrol FTW!!
J
phatphord
Scorpilow
Cheers jim. Plan was for a single SU,I've got a 'big book of SU's and their tune up settings' in the shed. What sorta vehicles ran a T25? Ford? Cheers again.
nissans ran a T25, as did some rovers mabe the T16 engine?
J
phatphord
Scorpilow
cheers. let the search begin!!
bstardchild
Club RR Member Number: 71
If I'm not mistaken Lotus Carltons ran T25's
Aaron
I've got the turbo&manifold from a Rover 820 Vitesse in the garage, I can check the casting marks tomorrow if you want to know the spec of the turbo?
Aaron.
1975 Toyota 1000 with 4A-GE (tweaked a bit)
1992 Nissan GTi-R (now sold after 17 years)
2001 Subaru Impreza WRX (remapped)
phatphord
Scorpilow
ay if you wouldn't mind
Aaron
No problem, just made a note on my hand - I've got the attention span of a goldfish.
Should be able to post details tomorrow afternoon/evening.
Aaron.
ratty
Rovers used T25 MG's like Metro, Maestro etc used T3
Fiesta RS Turbo used a T2
Aaron
Just back in from garage, got some info off the turbo but don't know if it'll be of any use to you :
On the inlet casting, it says "GARRETT A/R .48M27"
On a tag on the centre bearing housing "S/N XE0517A" "P/N 465199-3S" "C/N PMF 10013"
I also measured the inlets and outlets :
Turbo elbow outlet to exhaust downpipe 56mm diameter Turbo inlet from exhaust manifold 39x50mm with rounded corners Airfilter to turbo inlet 52mm diameter Turbo to plenum chamber 34mm diameter
Aaron.
phatphord
Scorpilow
Thanks mate, info noted
