Feb 22, 2013 19:29:22 GMT
Bought a 2.0 petrol Transit unseen via someone else as it failed the MOT on rear welding. Had a look at it today and even though it's only got 98k miles, it needs the usual rear chassis welding, along with rear crossmember and floor too. It's in good condition otherwise, but needs the lpg system looked at apparently, although it runs fine on petrol. Has recently had a new clutch, tyres, and exhaust and been used for the last couple of years as a car - so no heavy work!
Looking for offers around £400, only have green slip of V5 at present but should have documents in a week or 2 if you're willing to wait.
Pictures to follow when I get another day off work.
Last Edit: Mar 27, 2013 7:58:38 GMT by madmalx
Feb 23, 2013 15:40:05 GMT
Any tax left on it? Pictures of the rot? Whats up with the LPG, is it the original ICOM pump in tank system - has an odd shaped tank with the valve on the end
Feb 23, 2013 19:35:36 GMT
It's taxed till next Thursday, lpg apparently needs a new filler nozzle but I'm only going off what the guy I bought it off said - no experience of lpg sytems personally. AFAIK it's the original lpg system, but need to move cover to check, will try and get pics at same time - not off work till Thursday unfortunately.
Feb 23, 2013 20:11:16 GMT
mk5 i'm guessing if it needs that much wekding?
Feb 23, 2013 21:14:44 GMT
Yeah it's a mk5,it's definitely saveable and looks in pretty good condition body-wise until you look at the rear chassis/crossmember, but a good welder would have it sorted in no time I think.
Feb 28, 2013 15:38:37 GMT
Last Edit: Mar 9, 2013 12:39:58 GMT by madmalx
Feb 28, 2013 15:40:03 GMT
Most of the grot is on the drivers side from what I can see, the door steps were repaired so seatbelt anchorages on fail sheet are fine now.
V5 turned up today, so it's ready to go.
Anybody interested in this, or even able to do the welding inexpensively for me?
Mar 20, 2013 20:31:26 GMT
Still for sale due to the usual timewasters /
maxlee
Mar 24, 2013 14:40:16 GMT
mate were its petrol chuck it on ebay i sold a K reg one last week for 600 put in the title lez compliant to think you can still by the panels to fix the spring hanger to
