maxlee
Feb 22, 2013 17:36:53 GMT
Picked this up 2 weeks ago new mot from today 157K It quite tidy I think for a ph1 with 2 or 3 little dents around it and some normal lacquer peal inside is clean bosh pump haven't looked to see what turbo its got fitted all windows and central locking rear wiper etc work on it 1 key for all the locks none of the locks have been screw drivered Drove it 8 miles to and from mot test center no nasty bangs on clonks temp gauge stayed at 80 and very slowly come up when left ticking over. back wheels sit up as they should. bad points are when its cold its a bit of a pig coughs smokes untill you give it a rev (i don't tend to do that cold turbo's and all that) so could do with some glow plugs or has a slight air leak some were :huh: once warmed up its fine lasted taxed in December so good run might do it some good or the pump setting up? put some fresh fuel in it for mot smoke cleared so didn't worry other bad point is the clutch did slip when it comes on boost if putting ya foot down but hasn't on last drive please read edited bit at bottom seams to drive fine when driving normally has a strange rip in the back seat that you can't see/notice unless your looking for it, ermmmm think thats it £300 will give £10 to the forum if it sells on here got the log book and mot and 1 key thats all I can say about it really :blush: any one interested give me a pm all questions thoughts welcome need to sell need the space got a reg top 306 coming tomorrow update: took it for a spinb round my privet estate today wile playing musical peugeots and the clutch dosen't slip on boost in 2nd I even tryed pulling the hand brake up building the revs up (1500~2K) and letting the clutch out slowly and it stalled so i'm guessing the clutch had some derv on it from me doing the fuel filter maybe Huh after stalling it started up no problems so its only a bit of a pig when stone cold
Last Edit: Apr 8, 2013 18:42:39 GMT by maxlee
v1xz
i'm retro
Hi, do you know if this model is a cam chain or belt? Also how bad is that clutch really? If I was to buy I'd like to drive it back to mcr.
1998 Merc E240 1997 BMW 728i 1998 VW Passat 2000 Kangoo 1999 Transit LWB 1999 Matiz SE 2001 Clio 1998 Golf GTi 1996 Ford Luton.... Retired.... Want a Motorbike... Got one... Yamaha WR125X... Missed RR sooo much... 1983 Porsche 944 1997 Celica 2000 Clio 1993 MR2 1992 MR2T 1989 325i Touring
these are belts, not very hard to do nor particularly expensive.
the coughing on startup could be an air leak as you suggested, typically this is the leakoff pipes which are £8 for a 1m length of 3mm bore pipe from a pug or citroen dealer, there are no other sources for it as the typically stocked hose is not metric being 3.2mm, or 1/8".
look at the area around the injectors, if this is damp its the likely culprit.
another common one is a failed non return valve in the priming bulb, about15 from a dealer again, this lets fuel drain back to the tank if faulty, which if the leakoff pipes are leaki9ng back also will make it worse.
maxlee
clutch appears to only slip when on boost
I have fixed 3 air leaks and 1/2 way through changing the glow plugs (work so only get evning time) and fitted new diesel filter
had it running the other night for 2 hours fans come in at just under 90 on the temp gauge all seams well just the cluch slip on bost and the smoke cold start problem
cluch kits are ?£40 on ebay and go up to around 80 so cheap fix few bolts and pipes and the hole front end comes off easy little cars to work on
as welsh pug said there belt and easy/cheap to do
Last Edit: Feb 28, 2013 8:07:22 GMT by maxlee
maxlee
maxlee
Mar 13, 2013 15:40:58 GMT
bump
maxlee
Mar 22, 2013 17:30:06 GMT
clutch has stopped slipping please read 1st post for people intrested if i have this still in 2 weeks time i'll chuck it back on ebay as now cluch is ok should sell
Last Edit: Mar 23, 2013 17:49:06 GMT by maxlee
£300 for one of these with a years ticket is a BARGAIN
I can see this being a bit far for me, but what's your postcode, please? Also is that a Bosch or Lucas fuel pump on it? Thanks
Corsa Apology Champion 2014.
maxlee
sold and collected last week sorry mate
