jamesp
Feb 15, 2013 13:35:20 GMT
ive got a volvo amazon and the rear brake has a quirk of locking for on reason making it a nightmare to push around the yard
i was told i need a special tool to remove the drum is that true if so what do i need please
Seth
Feb 15, 2013 13:42:23 GMT
Yes, you need the proper sort of puller. I think PaulH (of well-used blue Amazon estate) has one so might be worth a PM to him?
jamesp
Feb 15, 2013 14:21:24 GMT
cool thank you ill serch and pm , idealy ill just copy it .
Feb 15, 2013 16:51:34 GMT
You might struggle making something strong enough. The axle on my P1800 & 1800S was similar, if not the same, as an Amazon and it took a hydraulic puller to remove the drum. Luckilly I have a decent (£300 Sykes and Pickavant set) but otherwise I'd recommend hireing one if you can't scrounge. Unfortunatley you are too far away from me. Article on Volvo rear hubs- www.sw-em.com/Brake_Drum_Notes.htmPaul H
Feb 15, 2013 19:20:50 GMT
Yes you really need the proper puller, I decided that this was just a sales pitch and I would use the 10 ton hydraulic puller I had.....WRONG! Broken puller, blow torch, drum and bent half shaft and had decided that nothing on earth would remove it. And then I tried the proper puller...... Wind in the nut ...BANG! And it's loose, no idea why, but it really is essential. Even with coppa slip, the drum / key way becomes solid in a very short time.
Feb 15, 2013 22:41:02 GMT
Last Edit: Feb 15, 2013 22:41:56 GMT by Deleted
topcat
Feb 16, 2013 12:12:21 GMT
I use my Sykes Pickavant 5 leg puller on mine. It never pulls off from twisting force alone. I fidd you have to wind it up tight, then a bit more and tap the end a few times with a hammer and the drum always releases.
