Before i take the car appart, I'm trying to find out what thread the fittings are for teh copper lines? into cylinders, the t piece, master and so on...
Does anyone know?
Its a 55 standard 10, But i think its the same as herald on the brake side of things...
Seth
It'll likely be the same imperial thread as pretty much everything else of the era which is 3/8UNF I think. If you measure the outside of a thread it'll be about 9.5mm. The spanners required will normally be 7/16 on a male fitting, 9/16 on a female fitting.
Briilliant, Thanks seth.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
I concur!
Use Kunifer pipe, it's not much more and it flares well, copper is ok, but Kunifer is better!
bl1300
It'll likely be the same imperial thread as pretty much everything else of the era which is 3/8UNF I think. If you measure the outside of a thread it'll be about 9.5mm. The spanners required will normally be 7/16 on a male fitting, 9/16 on a female fitting. Thats whats on my Triumph 1300
Current fleet.
3/8 unf as i bought all the bits to do my dads one a couple of weeks back.
1977 datsun 810 180b estate
