Hi, can any one please tell me if the heater box for a mk2 escort, as i have one fitted in my rickman,has a plaice where any water gets in can drain out, the top air vent is in the bonnet faceing up , but when we have rain( which seem,s like most day,s ) the carpets on the n/side get wet, when pulling off the outher day it was like a tape had been turned on, it seemed to be comming from inside the heater box, next on the list will be a scoop to cover the vent, john
I think the vent under the bonnet is a Rickman part. While I had the cylinder head off mine I did notice drain holes in the bottom of the intake box. Might be worth checking that the drains are clear - it's not a problem I've had at all, and it's unmodified, so it is possible. Mine leaks through the windscreen seal instead...
So does mine on the left hand side
Anglia68
Powered By Boredom.
I think the door seals on mine are fubared and that's where the water's getting in on mine because when I stripped my heater a few years ago there was no water in it.
I used a tank cutter to put a hole in the passenger side footwell, problem solved. ;D
That must be a standard mod on the rickman , lol, do you know that a metro 2 door are the same size around the door , the rubber bit that seal,s are a bit wider,better seal,
Anglia68
Powered By Boredom.
No, I didn't know that, that's a useful tip, thanks.
rickyr
Cannabalised the door seals off a Sierra mk II for my Rickman doors. Need to give the doors a good slam now but it does make a better seal.
