Jan 27, 2013 15:28:31 GMT
Hi my e 34 sakes when I get up to 50 miles Per hour I got told it was my tyres so I changed Them but still does it . Had wheels balanced Please help any advise Thanks
Jan 27, 2013 16:10:12 GMT
While driving along or braking?
Jan 27, 2013 16:27:28 GMT
Hub flanges clean?
Has it got aftermarket wheels? If so does it have hubcentric adaptors?
Jan 27, 2013 16:37:16 GMT
It does it while driving it is fitted with e 39 wheels Thanks
Jan 27, 2013 16:59:03 GMT
It does it while driving it is fitted with e 39 wheels Thanks the hub bore is larger on an e39 than the e34 (74mm to 72.5mm) this means you need spigot rings to run the wheels or you will suffer with wheel shake. the spigot rings arent expensive and should solve your problem
Jan 27, 2013 17:01:14 GMT
*bang* What an answer! The knowledge displayed here! Exceptional Ian
1971 Range Rover 1977 Jeep Cherokee 1982 W123 Merc 230CE 1992 Peugeot 405 TD Saloon 1995 Peugeot 405TD Estate (having a rest) 1990 Peugeot 205 CJ - For Sale 1985 Peugeot 305 GTX 1979 Honda Accord MK1 1995 BMW E34 TDS 1994 BMW E34 TD 1998 Mercedes 320 CLK
Jan 27, 2013 18:36:06 GMT
Thank you very much everyone
Smiler
Jan 27, 2013 20:24:28 GMT
Just for your own information, as I think joem83 was heading toward, if you ever get vibration under braking it could well be the upper arms of the front suspension have worn. I had this on two of my past three E34's. Quite a common thing with these old cars.
sphinx
Jan 27, 2013 21:59:00 GMT
One other thing worth knowing (although I'm fairly sure the e39 wheels without spigot rings is your issue) is the front inserts can wear. On my old e34 the shaft had worn inside the insert and there was lateral play which caused a massive wobble under braking.
retrobastard
Tits or tyres means trouble
Jan 27, 2013 22:05:53 GMT
eko
Jan 27, 2013 22:20:17 GMT
Bezel ive got a recently recond steering box and a set of 100 mile old front discs/pads sat in my garage doing nothing. Good to have in as spare if your interested in making me an offer?
BMW E30 24v
My vote goes for the bushes being worn. I had wobble at 50-60 and upon braking with my e34. Buy Powerflex bushes and your problem will go.
Currently: 1974 Beetle - Golf -
Previously: e38 735i, e34 525iSE, 1972 Beetle, 1991 Scirocco Scala, Morris Minor, 1983 Polo Breadvan, 1991 Mazda MX6
MonzaPhil
Think like a man of action, act like a man of thought
Control arm bushes cause horrible wobbling/shaking so another vote for that...
This is now a clicky linky!
Control arm bushes cause horrible wobbling/shaking so another vote for that... yes they can, if worn - but E39 wheels with no spigots will almost always do this at some point. So def worth doing them first, as even if it doesnt fully resolve the issues, it will help as the wheels will actually be correctly located. (especially as its cheap, and simply involves wheel removal and immediately putting them back on)
bortaf
Allways changing those bleeding things, they are the modern equiv of the cortina void bushes
R.I.P photobucket
help needed bmw e34 shake ChasR
@chasr
Club Retro Rides Member 170
Control arm bushes cause horrible wobbling/shaking so another vote for that... yes they can, if worn - but E39 wheels with no spigots will almost always do this at some point. So def worth doing them first, as even if it doesnt fully resolve the issues, it will help as the wheels will actually be correctly located. (especially as its cheap, and simply involves wheel removal and immediately putting them back on) Precisely. Having a few issues on the car (even if they do not seem to directly relate to the issue) IME never helps with diagnosis.
Ultimately I got the bushes replaced, the wheels balanced, the tracking done and replaced the discs. It does seem to be a combination of things. But apparently on an e34 it is mostly the bushes. I guess the wheels without spigots exaggerated the problem on this car.
Hi today I tried to shake the ns front wheel And it has some play will this be wheel bearing Or what advise please Thanks
