Jan 29, 2007 22:01:11 GMT
I'm trying to find out what way would be easiest to get rid of the rust. I have a few rust bubbles, which means wire brush, rust fighting agent, filler (?), primer, paint. I don't have access to a compressor to paint it properly, but what kind of finish can I get with aerosols? Heres pics of what I need to tackle: Adam
Jan 29, 2007 22:07:34 GMT
You can get a perfect finish really with aerosols, but same as all painting preparation is the key. Main difficulty is getting a colour match which depends on how weathered your paint is. You can get colour matched aerosols made up as well which are a bonus. but as its your first time normal ones should suffice. To repair the window blebs the the best way is removing the glass and seals and welding a new piece in. If you grind away fill and paint it it will need doing again in a year and a half or so, but it depends how long you want teh car for.
Jan 29, 2007 22:14:45 GMT
Really I want to do it as properly as I can, but I don't want it to turn into another project. How long do you recon taking out the windows, cutting out the bits, making new bits, welding them in, grinding them down, filling them and painting them take? 1 man working 8 hour days?
Adam
Jan 29, 2007 23:08:35 GMT
For whats there you should be able to do it in a day no problem (even allowing teh time for the paint to dry) But I recommend you get some assistance in removing the windows. Not bad to do when you have done it before but its a mare when its your first time.
rod
Young Adam ...watch you don't set light to the interior trim !!.Scabby areas in those positions always seem the worst to repair and are a pain in the A**se. You may get away with round the window ,by lifting up the rubber and seeing how far its gone ,B4 ripping it all out !
All seats etc will come out and i'll cover everything else before getting started! I'm sure my dad will give me a hand with the screens. Won't be doing anything paint related until the weather gets a bit better though
LowStandards
Club Retro Rides Member 231
Please don't go buying aerosols from the likes of Halfords etc. You might as well spit the paint at the panel! Take a trip to your local automotive paint factors and get a tin mixed up. I recommend the 'Holts' cans, if its a good place they should do them. Thay have proper tips on the can and spray just like a compressor, unlike the Halfords jobbies which have the same tip you'd find on a tin of deodorant (you laugh, but have a look)
There about £9 a tin, so its a few quid more, but you'll see the difference!
Jan 30, 2007 10:04:32 GMT
This side was done with 2K aerosols.... outside in the street ;D Preparation is the key to a good finish
Jan 30, 2007 10:54:38 GMT
My local paint shop will get give me 3 cans of primer and 3 of celly tornado red for £35. Not bad! A months allowance though.
Jan 30, 2007 11:55:23 GMT
If that's Automotive Paint Supplies in Newbury, they're very good indeed. Only place I know where the bloke can identify the make and model of car from just seeing the fuel filler door (best way to get it perfectly-matched is to take a (small) part of the car in with you).
Jan 30, 2007 11:56:37 GMT
ditto what everyone else said really. Its almost all in the prep. Use decent aerosols to make your life easier, but even with the Halfords ones you can get a decent finish.
Jan 30, 2007 12:34:25 GMT
If that's Automotive Paint Supplies in Newbury, they're very good indeed. Only place I know where the bloke can identify the make and model of car from just seeing the fuel filler door (best way to get it perfectly-matched is to take a (small) part of the car in with you). It is indeed! The guy there seems quite helpful and quite interested in what you're doing with it. Adam
425ci
Jan 30, 2007 13:16:08 GMT
Only place I know where the bloke can identify the make and model of car from just seeing the fuel filler door Very impressive, but I bet you'd stump him if you took the whole car in and asked him to tell you what the fuel filler flap was. Mike
Current vehicle: Mountfield Mirage 3.5hp (18" cut)
Jan 30, 2007 14:42:26 GMT
Only place I know where the bloke can identify the make and model of car from just seeing the fuel filler door Very impressive, but I bet you'd stump him if you took the whole car in and asked him to tell you what the fuel filler flap was. Mike Bring back 'you bet' but without mathew kelly. This guys skills need to be seen by the nation ;D
