Vw Polo Country 1300. I have recently bought something more modern to get me to and from college. The polo isn’t immaculate but is certainly presentable. The bonnet, drivers door and N/S rear quarter have dings in, other than that it is very straight. Its done 91,000 miles and since in my ownership its had the oil changed twice along with a new air and fuel filter. The car has a sundroof that has leaked for a while before my ownership because the seal isn’t tight enough. Theres a small amount of surface rust coming through on the rear arches. Brakes are fine and so too is the handbrake. The exhaust basically rusted through right at the end and fell off but I kept it so could be welded back on.
Good Points
MOT end of May 2013 and Tax end of January 2013
Cheap to tax and insure
New radiator
New wheel bearings front N/S and O/S
New O/S CV joint
New fuel pump
New numberplates
Original pierberg carb running well
Great little project
Bad points
O/S rear wheel bearing
Exhaust backbox broken
Oil filter was loose and dripped onto the exhaust causing some smoke when stationary
Tyres are not great
Sunroof leaks
NEED UP TO DATE PHOTOS
Will be a great little winter project for someone,
£350 collected from South Wales, NP13. If you're interested give me a call or text on 07866113617. THANK YOU.
Good Points
New radiator
New O/S CV joint
New fuel pump
New numberplates
Bad points
Tyres are not great
Sunroof leaks
