87iroc
Jan 28, 2007 16:39:05 GMT
So I've finally finished the Electric cut out install on the camaro heres some pics. i've place the switch where the boot release once was. I also stripped down the centre console so that the wiring is routed neatly under it and also under the carpet . I then drilled through the floor pan above the cutout and used a rubber grommet to cover it all up. Its a nice clean install and i've managed not to drill into any of my plastic incase i take it all out again. not the greatest quality , because they were taken on my phone , but heres a couple of vids s4.photobucket.com/albums/y149/craigthejones/?action=view¤t=MOV00016.flv s4.photobucket.com/albums/y149/craigthejones/?action=view¤t=MOV00014.flv i'll get you some good pics and video footage once i get my hands on a digital camera
Jan 28, 2007 16:43:02 GMT
Haha....just the job for scaring small children! I know that's not the point, it's just the way my warped mind works. Like it a lot!!!
Jan 28, 2007 17:27:17 GMT
Oh my! I was thinking about these recently! How easy did you find to install - do you have to make up your own piping for it? Do you think it makes a difference? I saw them on an SBC a while back and they seemed really good for terrorising people at the traffic lights...... ;D It'd be fun to have one on mine as it runs to a single system so I could have it in the middle, still have some silencing at the rear for cruising but not totally loose out on backpressure
Last Edit: Jan 28, 2007 17:30:06 GMT by Lewis
Jan 28, 2007 17:49:04 GMT
does it leak? I used to know a few people who fitted the cable-pull type which were popular and they used to leak and sound a bit nasty when "closed" and tricky for an MOT pass. I've been eyeing some of these up for a while though...
87iroc
Jan 28, 2007 18:05:24 GMT
The install was easy . all the parts needed come with the kit and requires only basic wiring skills . a welder and disc cutter would be good or you could just go to your local exhaust shop The cutouts do not leak at all at the moment but who knows long term My mate is a supplier of these kits and sells them for a cracking price so if your interested PM me. As far as power is concerned i don't think there is a huge difference but i'm putting it on the dyno to see what difference it makes, i know it really improves power on turbo'd engines where back pressure isn't as important
Nah, these wired ones leaked from day one. Cheap cast iron junk from JC Whitney.
LMK how much these come out at as I know how much the ones I've been eyeing in Hot Rod cost...
Nathan
Club RR Member Number: 1
Electric cutout install complete Nathan
@bgtmidget7476
Club Retro Rides Member 1
Jan 29, 2007 12:17:18 GMT
Pardon me for being dumb but what is it and what does it do?
Jan 29, 2007 12:32:18 GMT
basically its a Y-pipe with a valve in it. valve closed the exaust gasses go one way, valve open they go the other. Mount it at the end of the exhaust manifold and you can by pass the exhaust system.
The early oners had little more than a flap on a piece of wire you yanked to open/close it but electricly operated ones have been out for a few years.
Nathan
@bgtmidget7476
Jan 29, 2007 13:26:41 GMT
Ahh I see, but why though, a possible Performance increase?
Jan 29, 2007 14:02:29 GMT
possibly... more for the noise
Jan 29, 2007 14:46:14 GMT
I keep toying with the idea of a pair of these. RR group buy at a big discount?
87iroc
Jan 29, 2007 18:48:35 GMT
You can benifit from some power gains although sometimes it is just a case of the power band changing. the noise however is AMAZING you don't get the benifit of the true sound on those videos
I know for sure my mate will give you a superb deal by for a group purchase.
If you guys are interested let me know. Just to make it clear for the mods i in no way profit from these and this post is not being used as advertisment
cheers guys
Jan 29, 2007 19:35:14 GMT
I'd be interested in one!
87iroc
Jan 29, 2007 20:23:33 GMT
Guys if your interested then ring Finlay ( dynoflow ) on 01522 853 858
he works from home and will answer the phone anytime. i have spoken to him and if you mention craig ( me ) he will sort you out
