RA40tony
Rollin' rollin' rollin'
Jan 28, 2007 11:51:22 GMT
When I removed the worn carbs from the new engine and fitting my clean mikuni 40 sidedraughts I found connected to... nothing. It was free to the atmosphere. Its on one carb only and i have no idea what it does. I don't want it to spill fuel all over something or suck curse word into the engine. Here it is: HELP!!!!
1979 Toyota Celica GT. Currently Gone.
1975 Toyota Celica ST. 13x7 Allycats, "the stick" applied. 100kW 4AGE... Sold
1963 Karmann Ghia - Lo & Slo, Sold.
1965 VW Fastback - cruising
1953 Oval Ragtop, work in progress...
Jan 28, 2007 11:59:43 GMT
cany quite work out what you mean mate!
street
6.2 ft/lbs of talk
Jan 28, 2007 12:20:56 GMT
Is it a fuel return?
RA40tony
Jan 28, 2007 12:33:47 GMT
Maybe fuel return. Got no idea. It just had an inch long piece of tubing on it when i took the carbs of the car.
Looks a bit thin for a fuel return. Some kind of vacuum feed?
street
6.2 ft/lbs of talk
Jan 28, 2007 12:39:08 GMT
The fuel return usually is thinner than the main fuel pipe.... but could be a vacuum, have you got one going to the dizzy if it has a vacuum advance? Edited because i'm still half asleep
Last Edit: Jan 28, 2007 12:40:20 GMT by street
Jan 29, 2007 17:51:09 GMT
Looks like a vacuum advance line thingie output. Need a piece of tubing to go to your dizzy then i take it
