Ok, I've decided to sell my KAD 4pots as I want to move to 10" wheels so new calipers are needed. These 4pots I got brand new from KAD about 3 years ago. They've been on the car for less than 3 years and have done about 250-300 miles max. i've had a couple of other classic cars over the last couple of years so the mini hasn't been used much other than a couple of short trips and to/from the MoT station. For 2013, the mini is getting some love and attention
These calipers and discs were bought direct from KAD . they are drilled for a 8.2" disc. they are standard calipers with the bolt holes drilled (by KAD) to pull the caliper closer in over a 8.2" disc ( their regular 8.4" discs machined down (by KAD)). The discs and calipers were done as a special order from japan to fit under some alloy wheels which I suspect must have been a 3piece split rim 10" alloy (very thin barrels). i've offered up a 6x10 100+ alloy and it won't fit, but theres not much in it. Therefore these may fit under some 10" rims (3 piece splits probably) but are fine for 12", 13" etc
When new
on car fitting new flanges last year
the discs have the superior cast holes, rather than the cheaper "drilled" ones that are prone to cracking
This kit will fit classic minis and a-series metros.
£370 ono (sale is for the calipers and discs only (will leave the pads in). new calipers are currently £469 and grooved discs are £106 from KAD.
cheers
Matt
When new
cheers
Matt
