Dec 26, 2012 22:26:53 GMT
Can anyone give me some pointers where to look,
my van died on me yesterday and one of the local mechanics recovered me and has had a look and confirmed ive got air in the system, now he cant find any diesel leaks and suggested i take it to my local Diesel pump & injector specialiat power drive of portsmouth.
before i do this, is there anywhere i should check? are there any known weak spots?
the vans been running fine, but was parked up for a week and now it wont even start without bleeding the system first, then withen 30 mins it conks again so its got to be letting in a lot of air, ive not had it apart yet but will do so monday
Ta
Dan
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Dec 26, 2012 23:56:09 GMT
only takes a little air to stall a diesel ,
check the bladder pump thing as these often go , the connections and bends on the fuel pipes and the fuel filter and housing,.
facebook: rodney dean / rd transport
Dec 26, 2012 23:57:41 GMT
T4's are common for the o ring on the filter housing leaking
bortaf
Dec 27, 2012 12:36:47 GMT
If it's not leaking out but air is getting in it will most likely be the vacume side of the system not a presurised side, IE anything berfor the main injection pump, pipes, lifter pump, fuel filter ect, 90% of the time it's the fuel filter O ring or the seal under the filter pump button (if you have one), does it pump up hard and stay hard for at least 10 seconds ?
R.I.P photobucket
cheers ill have a look later, ordered a new fiter, o-ring and valve
Dec 28, 2012 13:54:04 GMT
its often handy to pop some clear fuel pipe in places to narrow down the air leak, ie pre fiter, after filter and any other areas before the pump.
Dec 28, 2012 14:30:59 GMT
Funnily enough I've been looking for clear fuel pipes and can't get em All my local motor factors have black rubber only
Any ideas where to get clear?
Dec 28, 2012 19:10:06 GMT
can get the correct stuff on ebay for a few quid delivered.
