mdw
Dec 21, 2012 14:30:07 GMT
I need to get a throttle cable for my bmw e30. It's a 316 with a weber so not that special. The problem I have is the normal bmw cables have barrels wand straight tubes on the end if I cut them off the cable is then too short.
So I'm thinking I need a custom cable, I've had a look on the Internet and none of them seem to do the right end for the pedal end. It's the usual hook fitting looks like a question mark shape.
Any suggestions?
1989 VW Caddy 1993 BMW 316/2.5 Touring 1985 BMW 316 (e30) 1984 BMW 316 (e21) 1992 VW Passat 1984 Porsche 924 - SOLD 1985 Volvo 340 GL - disfigured Now cubed 1990 BMW 318i - Sold 1989 BMW 535i SE - executive express SOLD
Dec 21, 2012 16:11:33 GMT
You can get a block that fits to the end of your thottle pedal, providing that is your pedal is made of round bar
Dec 21, 2012 17:37:17 GMT
I usually use bicycle brake cables - the better quality ones with PTFE liner.
Nick
mdw
Dec 21, 2012 18:40:58 GMT
I usually use bicycle brake cables - the better quality ones with PTFE liner. Nick I thinking of doing this but it's just getting hold of the correct end to go on the peddle
Dec 21, 2012 19:02:34 GMT
A traditional motorbike dealer / shop / repairer will be able to make or alter cables.
Paul H
Dec 21, 2012 20:17:11 GMT
If you're going to try bike brake cables, there are three different ends, so worth looking at different ones to see if any suit. We used Road bike cables on a friends class 3 autograss car without any problems at all. All else fails, try somewhere like www.cable-tec.co.ukThey should be able to help
RobinJI
Dec 21, 2012 20:56:53 GMT
On the Scirocco I used a mountain bike brake cable with the cable end at the throttle body, then to clamp the pedal end I drilled a small hole in the shaft of an M-8 bolt (against the side of the head) and bolted it through the hole the hook used to go through so it clamped the cable against the side of the pedal. Works just fine.
With bike cables as well as the 3 different ends (mountain-bike brake, road brake and gear) they come in wound or braided varieties too, with the braided ones being quite a bit more resistant to fraying and kinking, and there usually stainless or galvanized options too. Gear cables and their corresponding outer casing are a touch smaller diameter.
Also if you need a really long cable, a rear one from a tandem bike is a good bet. Any good bike shop will cut the outer casing from a role to your specified length and then give you a choice of a few types of inner cable.
Last Edit: Dec 21, 2012 20:58:51 GMT by RobinJI
rodit
Dec 22, 2012 17:54:37 GMT
If you want a cable designed for the job search Aldon automotive based in brierly hill. Definitely know what they are doing.
Low and slow
Why can't i tune it?
Dec 22, 2012 19:22:00 GMT
Dec 22, 2012 23:22:27 GMT
When I fitted a Nikki carb to my 1200 Beetle I made a 13' long choke cable out of bicycle bowden cable soldered into a choke knob from the "spares box". Worked fine. When throttle cable snapped I simply swopped over the choke cable and used that as a hand throtttle to get home Paul H
