Dec 19, 2012 20:54:18 GMT
Hi folks.this may seem like a silly question bit I need somw help/tips fitting a K&N filter to my Sierra.its a 2.0 DOHC if that makes any difference.i have been told that I could saw down the standard airbox but I really don't want to do that.anyone got some tips,pics orca link that could help me.its the first time ive done this and I really don't wana f**k it up.
Cheers guys Matt
Dec 19, 2012 22:15:04 GMT
Induction kit should have all the bits in it you need to replace the airbox.
Dec 20, 2012 11:26:30 GMT
If it's the injected one it has an air filter box and another resonator box. If it's a 57i kit then, as popuptoaster says, it'll replace all of that and also have some plumbing for the idle control valve.
Somewhere in the depths of my photobucket account I have a pic of a fitted kit I think, I'll have a look.
Jaguar S-Type 3.0 SE
Dec 20, 2012 11:30:42 GMT
Not as helpful as I'd hoped. Your airbox and the resonator box will be at the front RHS. The idle valve was aomewhere hear the left hand strut mount I think.
Dec 20, 2012 13:07:59 GMT
Different car and engine but the same principle, filter goes where the airbox would have been, proper kit will have a bracket to support the end of the hose and filter and any extra pipework required.
Copey
Dec 20, 2012 13:13:19 GMT
how i did mine...by doin the thing you don't want to do haha
Dec 20, 2012 13:17:57 GMT
I'm not a fan of cone filters, most cars don't need them, the Cortina had one because there wasn't room for a stock airbox and it saved making one.
However they DO sound quite nice, although I have managed similar results just adding holes to a stock airbox. i had to open up the already fitted but blanked cold air feed in the airbox on my Volvo when i turned the boost up and it makes noticeably more noise.
Copey
Dec 20, 2012 14:38:29 GMT
aye, as Mr Toaster has said, not needed really, but they do make a good induction noise
Dec 20, 2012 15:30:02 GMT
Just chuck a nice K&N panel filter in the air box, most induction kits on standardish cars do very little.
Dec 20, 2012 15:37:41 GMT
how I did mine...by doin the thing you don't want to do haha If you're going to do it I'd follow Copey's approach. Personally I think it looks much better than mounting the filter straight to the throttle body, because you don't have to stuff the idle control valve somewhere. Just use a hack saw and carefully cut the pipe as close to the resonance chamber (the black box after the air filter).
Copey
Dec 20, 2012 16:09:09 GMT
really is the easiest option, like you say don't need to relocate the ICV or anythin, just a couple of mins with a hack saw, or, if youre as lazy as me, angle grinder haha
Dec 20, 2012 17:28:52 GMT
As above really. When I do mine, ill be chopping, and leaving the ICV in its proper position.Looks way better IMO.
Granadaman72
I likes Granada's, Cortina's, Sierra's, Viva's, Marina's....................
Dec 20, 2012 17:37:11 GMT
This is how i did it on my old Granada, exactly the same layout. I extended the pipe with an off cut of black drainpipe and even used a downpipe bracket with a spacer screwed to the reverse of the radiator panel, didnt take long at all. The DOHC sound very nice with a cone filter too
The DOHC does sound good with a cone filter on it, I have to agree. I'm tempted to attack the airbox on my Audi with the spade drill bits over christmas to make it sound a bit more rorty now.
