RobinJI
Dec 18, 2012 19:41:08 GMT
As in the title really.
I'm Just musing some ideas for the brakes on my Scirocco. At the moment I've got 280mm Golf G60 discs on the front, with the standard VWII calipers on them, but I've got plans to fit some 4-pots I've been offered dirt cheep on there. They'll need custom work to make them fit, so I can basically use whatever size discs I want, and in fact the bigger they are the easier the calipers will be to get on there (as long as they fit under my wheels).
I'm struggling to find anything much larger than my 280's though. Some Rover/MG's use 282's with a thicker disc and deeper bell than the VW ones, which could be handy as the deeper bell will give more clearance between the caliper and the back of the wheel's spokes, and the extra thickness should help them vent a little better. But they're the largest I've found with a 4x100 bolt pattern.
So does anyone know of anything larger?
Rich
Club RR Member Number: 160
Biggest 4x100 brake discs?Rich
@foxmcintyre
Club Retro Rides Member 160
Dec 18, 2012 19:56:59 GMT
If I can find it you can borrow my brake parts book which lists everything by dimension. Just flick through looking at stuff you know is 4x100 and it tells you bell depth and disc thickness and all.
Dec 18, 2012 19:58:16 GMT
Check out APEC braking, their website allows you to put in key dimensions and will show the options. Unfortunately pcd isn't an item you can search on but thickness, height, and centre bore are, which is a good help
`state
Yorkshire and The Humber
Dec 18, 2012 20:00:42 GMT
In the vauxhall world the biggest discs are 288mm cav/vectra v6 discs BUT they`re 5 stud so we have to have them redrilled. Although I'm sure theres a dealer that sells them in 4 stud i`ll check if 288`s take your fancy? I'm sure they`re about 60 quid apair.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
jamesv
Dec 18, 2012 20:05:41 GMT
Apparently the old TSR 285mm kit used to use some sort of Rover discs I think, I've got a set of the adaptor plates, but not the discs, as I'm now just running 280mm spacer plates and G60 discs on my Mk1, the discs for the 285mm TSR kit were from Black Diamond, but I've never had any joy getting it out of them what they were originally from...
James, Mk1 Golf 16v ITB'd, RS's, TT interior - in bits Affalterbach tweaked CLK - commuter mobile And a couple of GSXR's
ovimor
North East
...It'll be ME!
Dec 18, 2012 20:13:17 GMT
BMW MiNi are big.... 4 x 100
Check them on 'Brembo Catalogue', Webbie.
OVIMOR
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
Onne
Dec 18, 2012 20:19:35 GMT
New Mini is 276mm as standard.
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
RobinJI
Dec 18, 2012 20:31:35 GMT
Ah, thanks ovimor, I'd forgoten that new Mini's are 4x100. They come in at the same thickness as mine (22mm) with 276, 294 and 316 sizes. Depending on what I can wedge under my wheels the 294 or 316s might work out well. A little thicker would be nice to suit the new calipers, but I can't see it being to much of an issue.
Good Scrap, thanks for that, I knew there was somewhere that'd let you search by size, shame you can't do stud pattern though!
James SV, yeah, the TSR kit had stuck in my head and using Rover discs of some sort, they must have been ~20mm thickness to work with the standard calipers unless the kit came with thinner pads too? Otherwise I'd expect they just used the 282's that I'd found and claimed them to be 285s.
Rich, Cheers, it may be some time until I've got the money to actually do anything, so being able to flick through a paper booklet might be nice. Don't waste too much time looking for it though, as I say, won't be for a while and I'm sure the web will come up with something before long. The MINI ones look good.
Last Edit: Dec 18, 2012 20:41:22 GMT by RobinJI
Dec 18, 2012 20:42:43 GMT
I've got mk2 g60 disks and vr6 calipers on my golf and they stop on a penny!
Well you will mess with these cars....
Mk4 golf gttdi highline. Mk2 golf 1.8T
RobinJI
Dec 18, 2012 20:53:11 GMT
Gaz, yeah there seems to be some nice set-ups from within the VW range, and to be honest I'd be pretty ok with staying at 280mm but with the new engine in there it definitely needs some better calipers. I've been offered a set of rather nice calipers stupidly cheap, and the bigger I can go disc wise the easier they're going to be to mount.
Looks like Renault do a 300mm 4x100 disc on the Scenic which looks promising too depending on wheel clearance. Offset's slightly deeper than G60's and they're slightly thicker.
Annoyingly nothing useful seems to use as large centre-bore as VW, but at least that's easily opened up on a lathe.
Looks like between the MINI and Scenic discs I've got some good options there to try out once I get my wheels down from the seller. Now I just need to work out if I really want to restrict my self to 16" wheels, as being able to use 15's as track wheels in the future could be a pretty big bonus.
Last Edit: Dec 18, 2012 20:55:42 GMT by RobinJI
Dec 18, 2012 21:21:28 GMT
My mk2 was running a 200bhp 1.8t with that set up,and this time I'm hoping for at least 300 and don't intend changing ;D,really happy with them,I also used a 22mm master cylinder
RobinJI
Dec 18, 2012 21:36:22 GMT
Yeah, I'm guessing the VR6 one's are probably way better than the VWII's I've got on mine, and would probably be fine. I want to really over-spec the chassis though, and I've been offered some Brembo 4 pots that measure up well for cheep, plus I quite fancy the challenge of making them fit.
I'm only running 150bhp at the moment, but the plans to get the suspension and brakes top notch while it's my daily, then when I've sorted out another diesel estate to run around in the Scirocco will become more of a toy and then it'll get track prepped and a lot more power.
Last Edit: Dec 18, 2012 21:38:05 GMT by RobinJI
Biggest 4x100 brake discs?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Dec 18, 2012 21:38:57 GMT
Fiat Coupe turbo disks are pretty massive and cheaper than Mini.
RobinJI
Dec 18, 2012 22:04:13 GMT
Hm.. not quite 4x100 but I guess it's pretty close, they'd likely bolt up as I'm using M12 wheels bolts for now. (Quite fancy going over to M14 studs sometime though, just to be on the safe side, and because studs are clearly better.) They come in at 305mm and a whopping 28mm thick and a little deeper bells than mine. Worth considering, good thinking.
Last Edit: Dec 18, 2012 22:05:03 GMT by RobinJI
Dec 18, 2012 22:11:35 GMT
Seat Ibiza Cupra R did come with 305mm Brembos, 4x100, should be a bolt-on.
Click picture for more
RobinJI
Dec 18, 2012 23:05:20 GMT
Thanks, yeah, a friend told me about the Cupra R set-up a minute ago. Sounds ideal but they seem to be very rare and expensive. I think I'm favoring the Renault ones at the moment, I can't imagine standard Scenic parts being expencive, and if Brembo's will fit under 16's on the 305mm ibiza discs, they should fit on the 300s easily enough.
Last Edit: Dec 18, 2012 23:06:19 GMT by RobinJI
Biggest 4x100 brake discs?Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Dec 19, 2012 10:37:05 GMT
^^^Scenic ones as you said look good. I don't know what access you have to pictures and diamentions but I can look stuff up at work and get pretty spot on info. If I can help just PM.
Last Edit: Dec 19, 2012 10:37:26 GMT by Robinxr4i
craig1010cc
Club RR Member Number: 35
Biggest 4x100 brake discs?craig1010cc
@craig1010cc
Club Retro Rides Member 35
Dec 19, 2012 12:13:14 GMT
Also why not look at 4x108 and redrill? Pug 406 V6 coupes came with pretty big stoppers on them
RobinJI
Dec 19, 2012 12:30:13 GMT
Thanks Robin, that photo got me thinking, the venting type varies between the different makes, and it looks like between the MINI and Renault discs I've got a choice of where the air's taken from. It turns out the Brembo site also lets you search by size, but even better than that (in my eyes anyway) they show really well dimensioned technical drawings of everything they list, with a cut-away view showing the type of venting used. My current Golf G60 discs: The Renault discs: MINI 294mm discs: MINI 316mm discs: Fiat Coupe turbo discs: So it looks like I've got the option of the venting air being drawn in from the front or the back of the disc, or from the centre of the bell, as well as the various sizes. Plenty to think about, I've just got to work out which venting method I think will be most effective. Edit, Craig, if none of these fit the bill then I will look into re-drilling, but there seems to be a fair few options out there in 4x100, I'm sure I can get something to work. The next headache's going to be how I mount the calipers onto the hubs, I think anything under 320mm discs are going to need the calipers machining back a little to clear the original mounting lugs as they clash quite badly. I'm actually considering making new uprights for it, as it'd let me correct quite a few geometry issues as well as being able to mount the brakes with a lot less constraints.
Last Edit: Dec 19, 2012 12:36:08 GMT by RobinJI
@robinxr4i
Dec 19, 2012 13:08:05 GMT
Crikey those Brembo diagrams give incredible detail! Given what you've already gone through with the Scirocco I'm sure you've get these fitted pretty sharpish.
