nitro
Dec 17, 2012 20:52:32 GMT
I'm looking to buy some vht anodised red paint for my rocker cover and maybee inlet manifold depending on how far it goes but as its anodised effect paint I'm unsure but if anyone else has use it and had good results il get some i no other vht paint is quite good but i just want to be sure Thanks in advance guys
Dec 17, 2012 21:20:04 GMT
VHT paint that actually goes to very high temperatures never seems to be very shiny, it always cures to a matt finish that likes to get oily and grubby.
On a rocker cover and an inlet manifold you'll get away with normal paint providing it's not something super tuned that gets dead hot.
nitro
Dec 17, 2012 22:46:13 GMT
It shouldent be too hot as I'm only running itb's on std bottom end but i will be turboing it soon when funds allow so don't wanna do them bits twice if i don't hafto. I had a look and the finish dosent look too bad when its used. There is still a part of me which is unsure tho so would like to see if anyone has used it its vht sp450 is the one I'm looking at
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Dec 18, 2012 12:47:03 GMT
We paint all our engines with a higher temperature enamel paint. Rated to around 200 degC so well within the confines of a normal engine.
Only things like manifolds need 'proper' VHT paint
Dec 18, 2012 19:46:14 GMT
speaking of VHT paint for exhaust manifolds, I bought some of their red paint, thats supposed to be useable upto 1000c (ish), but after less than 200 miles driving the paint on the exhaust manifold had faded and burnt off. this engine was only used on short journeys and wasnt revved about 3000 rpm. the manifold was grit blasted before painting too. I then got some cheap high temp paint for exhausts off ebay (less than £7 inc. delivery), and that lasted much better
sowen
Club RR Member Number: 24
experiance with vht paint?sowen
@sowen
Club Retro Rides Member 24
Dec 18, 2012 21:10:24 GMT
On my Rover P6 I've got normal cellulose paint on the rocker covers and they have not showed any signs of deteriorating over half a year. The turbo exhaust manifold is made from thinwall box steel and painted in barbeque paint, which is slowly deteriorating but I'm impressed it's lasted as long as it has considering what it is.
nitro
Dec 18, 2012 22:06:34 GMT
I'm think I'm gonna go for the paint been thinking, my block is gonna go black and all the other bits will be anodised red frm vht, il see how it goes don't think il get any this side of x-mas depending if someone local stocks it
