ger
Nov 30, 2012 15:47:02 GMT
Hi Folks, Looking for some components to build a solution to my space issue.. Problem: Garage is just wide enough for 2 cars, but in order to fit 'em both in, one car needs to slide aside. I've used wheel dollies, (machine mart), Go-jack type things and mobile axle stands and they all kinda work. The pain is having to jack the car up in order to get in or out ! I'm looking for a drive on-drive off system. Solution: A couple of drive on ramp type things mounted on a rail for ease of sliding ! I want it to be super low so it does not get in the way To make it work I need some really tough wheels/rollers and a rail for them to run in ! Any thoughts on where I can source, (cheaply), something like this....(to run on top of a angle bolted to floor) ![](http://img28.imageshack.us/img28/8837/1wheel1.jpg) Uploaded with ImageShack.usReckon I'll need about 20 of them. There are commercial systems available but too expensive for me ! Cheers Gerry
joda
Nov 30, 2012 16:08:41 GMT
At the Footman james show last weekend in Birmingham I saw a company with motorcycle movers, they would be ideal for what you are looking for, see if I can get a link ![](http://www.cjautosheywood.co.uk/MB0303.jpg) if wide enough for a car wheel, 2 of these would make a roll on roll off car mover i have a slightly bigger than a double garage with 5 cars in it, 3 are moved into place by the traditional wheel skate type
Last Edit: Nov 30, 2012 16:11:18 GMT by joda
Nov 30, 2012 19:07:57 GMT
Nov 30, 2012 21:16:11 GMT
I've used two sheets of hardboard before, like the back of a flat packed item, shiny sides touching and really surprising how easy you can slide a car about on them!
ruffgeezer
Attracts french tat.
Nov 30, 2012 21:56:53 GMT
I'd go for a set of wheel skates, they'll fit on any car then.
i made 2 H frames from box section with caster in each corner, one under each axle. no channels to get blocked up or rails to trip over.
theres more to life than mpg & to much power is just enough.
jamesp
put 2 metal strips on the floor then park on baking trays itll slide
Davey
Resident Tyre Nerd.
We have a four post ramp at work with a rolling jack, the wheels of which are steel centred nylon these run in a chanel on each side of the ramp something like that could work. ![](http://www.boston-ge.com/images/pit_jack2_l.jpg) Like that but nylon wheels and sideways rolling could be possible and easy too make.
Dec 13, 2012 14:39:04 GMT
when i had my first garage it had a single up and over door but it was a double unit, i went out and found 8 14 ft half inch thick angle to run across the garage as rail's then i made 4 trolleys to carry each wheel then i could drive what ever size car up on to the rollers and then push one to one side and drive the other along side it
Dec 23, 2012 11:24:43 GMT
Source a local gate manufactur. They will be able to supply the track to sink into your garage floor and the special rollers to match, i used to work for a comoany that made roler gates' anD its all pretty cheap. A
Toyota mk3 supra. retro goodness.
Dec 27, 2012 20:11:11 GMT
go to your local shop, wait til the bread delivery and scam the trolleys the bread baskets come on, cut and shut they work perfectly, everything from an Imp to a Landrover get moved on mine
retired with too many projects!
bazzateer
Imping along sans Vogue
go to your local shop, wait til the bread delivery and scam the trolleys the bread baskets come on, cut and shut they work perfectly, everything from an Imp to a Landrover get moved on mine Keith! That's naughty! :-)
omega
Dec 28, 2012 11:52:57 GMT
go to your local shop, wait til the bread delivery and scam the trolleys the bread baskets come on, cut and shut they work perfectly, everything from an Imp to a Landrover get moved on mine Keith! That's naughty! :-) but cheap!
