Nov 30, 2012 13:01:10 GMT
Hi all,
I have a 1996 Peugeot 406 1.9 turbo diesel. It has the Bosch fuel system so I use veg oil in it without any problems.
I'm looking to get a smaller car and am totally hooked on the veg oil thing so am wondering if anyone has some suggestions for a suitable car? I'm looking to just add veg oil without doing any mods.
I was looking at a 306 (with aircon) or late 205 but am told these only came with Lucas/CAV fuel systems. Any idea whether this is correct?
Thanks,
Straggler.
Tepper
Nov 30, 2012 15:00:09 GMT
Plenty of 205's are fitted with the Bosch pump, I think only very early 306's had the Bosch pump. Swapping a Lucas for a Bosch isn't too hard, there's a guy on the 306oc who will do the swap, change the cambelt and tune the pump for £100. I may be wrong here, but I think the Bosch pump is quite common on Citroens like the ZX and Xantia? Happy hunting!
1989 Peugeot 205 GTi - stolen! 1983 Mazda RX7 1968 Rover P6 - also stolen.
Nov 30, 2012 15:26:27 GMT
I thought it was the N/A diesel 205's that have the majority of the Bosch pumps. I think It's the 205 TD's that mostly have the Lucas ones ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Nov 30, 2012 15:41:34 GMT
I thought it was the N/A diesel 205's that have the majority of the Bosch pumps. I think It's the 205 TD's that mostly have the Lucas ones ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) My old 205 (F reg, non turbo) had Lucas. Any ideas about the 1.4 turbo diesel in the Seat Arosa? Running one of those on veg oil would be seriously cheap motoring.
bl1300
Nov 30, 2012 17:03:13 GMT
on the same front would anyone know if my Mitsubishi L200 is suitable for running on veg. Its the 2.5td 4D56 lump and it was originally fitted in a mk2 shogun.
Current fleet.
Kieran
Nov 30, 2012 17:36:29 GMT
Citroen ZX?
Clio mk 1?
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
craig1010cc
Club RR Member Number: 35
cars suitable for veg oilcraig1010cc
@craig1010cc
Club Retro Rides Member 35
Nov 30, 2012 17:39:59 GMT
I thought it was the N/A diesel 205's that have the majority of the Bosch pumps. I think It's the 205 TD's that mostly have the Lucas ones ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) My old 205 (F reg, non turbo) had Lucas. Any ideas about the 1.4 turbo diesel in the Seat Arosa? Running one of those on veg oil would be seriously cheap motoring. Thats a modern TDi, don't think you'll have any luck there (like mk4 golf's).
Tepper
Nov 30, 2012 18:16:26 GMT
My old 205 had the Bosch pump, J reg, and I've definitely seen some 205 TD's with the Bosch pumps as well. I think it just depends on what they had lying around! This might shed some light: www.dieselveg.com/Vehicle%20List.htm
MattE
VW AAZ 1.9TD or the Y1 engines, any peugeot/citroen with the manual bosch pump will run on veg, i`ve got a 205 running on veg and will be looking for a VW td early next year.
omega
it appears that anything with a bosch pump is good,lucas is bad,and all new diesels are bad
geeza
Dec 11, 2012 12:03:08 GMT
In this cold weather I would add some derv into the mix or even thin with £5 unleaded petrol to a full tank! 1st time using veg in a tank you should drive for about 500miles and then change the fuel filter as it drags up all the crud out of the tank
Dec 11, 2012 12:19:24 GMT
Any ideas about the 1.4 turbo diesel in the Seat Arosa? Running one of those on veg oil would be seriously cheap motoring. My old boss ran a Polo with that engine on veg oil. He ran a heat exchanger in the top hose and had a plastic tank in the boot for diesel plumbed in on a changeover valve. In the winter he'd start on DERV, run it for a minute then switch over to veg in the main tank, then switch back a couple of hundred yards before turning it off to flush the veg oil out of the pump. The heat exchanger was very simple: just a couple of feet of rubber top hose with a tee at each end and a bit of small bore copper pipe through the middle emerging from the tees though the middle of a plug. All held together with jubilee clips. He ran it like that for a few years before selling it on I think. I used to get a lift in to work in it quite regularly for a while.
