Recently bought this 2000 Vauxhall Corsa B 1.4 sport as a 'fixer-upper'. Usually I wouldn't have bothered but I had never seen such a clean example of a corsa b and thought it was worth saving from the scrappies.
The car has had two owners from new (aunt and nephew, (not mine)) and it had been dry stored in a garage for the last two years.
It had an air leak and a missfire so we replaced the upper and lower inlet manifold gaskets and did an oil filter and spark plug change and now she runs great.
It has between 60 and 70k miles, can't remember the exact milage.
It has an irmscher front splitter and sideskirts, a saxo vrt spoiler bonded onto the standard spoiler and 17" oz alloys.
My plan was to put it back to standard and sell it but with the cold weather coming in fast i'm going to cut my losses and put it up for sale so I can get something rear wheel drive as a play thing while my S13 is off the road for the winter.
It currently has no tax or mot but can be mot'd at extra cost.
Will need rear lights for an mot as one is cracked (can be supplied at extra cost) and will also need numberplates made up as it had personalised plates on it which the previous owner kept. (new numberplates can also be provided at extra cost)
As I said before, its a very clean example (otherwise I wouldn't have bought it with no mot) the only rust I have found on it is the underside of the bonnet which is apparently a very common problem with corsas.
This would be a perfect first car for someone or just to use as a cheap run around.
Will take £550 for it as it stands or swap for something rear wheel drive (Volvo, bmw etc)
Probably best to text me if you are interested as I don't come online often.
Text - 07961006430
Sorry about the rubbish photos, they are the only ones I have.
Text - 07961006430
