I've got a double axle trailer fitted with mini 10" steel wheels. The tyres are shot so I want to fit a set of 12" mini steels
The offset of the 12" wheels is slightly different so I need longer studs to allow the nuts to fit on fully
The studs use the mini thread size but are screw-in rather than tap-in
The only studs I can find that are both this thread size and screw-in are exhaust manifold studs
I am wondering about the suitabilty and durability of fitting manifold studs in place of wheel studs?
I have bought a set and they do fit in terms of length and the centre spacing etc but I don't about their strength?
Thanks
James
Thanks
James
