have decided to get rid of my sportrak, I reallly havent got the heart to scrap it, its way too good for that, has a couple of things that need sorting and I just don't have the spare funds or time , if I was gonna keep it I would but I just don't use it enoug to justify it.
bad points....
Mot has just run out, 6th nov,
wont start, fuel pump doesnt seem to want to play, tho it did fire up the other week, ran untill the fuel that was pumped through was used up, then didnt want to play again.
lower radiator hose leaks, - I fitted a 2" body lift , this raised the radiator, but as the fan on the engine and not an electric one, the tips of the fan rubbed on the hose and eventually wore through it.
needs a patch on the sill , my fault, when fitting te lift kit I jacked the body up where there was a patch and its kinda deformed it, needs re doing .
slight dent in drivers front wing.. I went to a play day , had a strap fastened to front tow hook and hooked it to the wiper to keep it outa the way... I then ran over the strap, pulling the wiper blade off and denting the wing
looks like itll pop out again tho,
wiper blade is missing, its some where near Blaunau ffestiniog
good points
all 4x4 bits work,
car is fitted with colway ctrax all terrain tyres, including the spare
fitted a new clutch last year, cars probably done about 500 miles on it
fitted 2 new milner leaf springs year before
runs sweet as anything ... well befor ethe fuel pump problem
2 " body lift fitted so I could fit larger tyres, I put some 15x8 wheels on fitted with 31" recip trial tyres, no rubbing
car is brilliant fun off road and in the snow, tho I have only done 3 play days at the local offroad center, I was surprised how well it copes with things.
so there ya go.. I'm after £200 cos I figure if I had to I could get that much weighing it in and selling the wheels tho id much rather someone bought it and got some use from it, plenty of life left in it
f could prove to be really handy if we get a loada snow again.
the car is taxed- just did it this month, but ill be cashing that in , unless the buyer wants to make an offer fo rit.
cheers peeps
I'm in Llandudno, North Wales
bad points....
good points
all 4x4 bits work,
cheers peeps
