Nov 18, 2012 14:31:55 GMT
I'm after a Toyota 12R (or 2R) engine, These were fitted to Hi aces, Coronas, early Diahatsu 4x4s Toyota hi ace 1978 twin headlight model think crossover model
If you happen to know of anyone scrapping a 70's Hi ace, series 1 or 2, due to rot there's a good chance it'll have the motor I want.
if you know a suitable engine I can bolt up to the gearbox in there
or where i can get parts to rebuild the motor in there as the camper is solid
Nov 19, 2012 21:38:12 GMT
Increase the options and go for an 18r 2 litre unit too. As fitted to the hilux as well as hiace.
Messerschmitt Kr200
Bond Minicar MkC
Fiat 126 bis
Mercedes W210 E320 Cdi
Peugeot 306 cabriolet
Citroen XM 2.1TD - BREAKING
Citroen Dispatch Combi
smart roadster
Nov 19, 2012 22:33:16 GMT
messerschmitt hi will it fit the original gearbox
18R
The 18R series shared a 2.0 L (1,968 cc) block; cylinder bore was 88.5 mm (3.48 in) and stroke was 80 mm (3.15 in).
The 2 valve, SOHC versions were as follows: Code Power kW (hp) Torque N·m (lb·ft) Years Comments 18R 64–66 (86–89) 142–145 (105–107) 1971–1981 18R-C 72 (97) at 5500 rpm 143–145 (106–107) at 3,600 rpm 1971–1981 emissions control - worldwide (Californian Standards) 18R-U 75 (100) at 5,500 rpm 152 (112) at 3,600 rpm 1975–1978 emissions control - Japan 18R-E 84 (113) at 5,600 rpm 172 (127) at 4,400 rpm 1974–1975 EFI, Japan only
Applications:
18R/18R-C/18R-U/18R-E 1972 Toyota Corona 2000 1972 Toyota Corona 2000 MK. II 1972 Toyota Celica 2000 197X Toyota Cressida 2000/Gen1 18R-C 1972-1974 Toyota Hilux, 108 hp (80.5 kW) 1974-1981 Toyota Celica 2000
Nov 20, 2012 12:31:00 GMT
jumped the gun on this one its a 75 so a lot earlier
Nov 24, 2012 10:25:01 GMT
anybody
Nov 26, 2012 10:59:35 GMT
i have an 18r if thats what you are after? came out of my celica and i put an 18rg in, was using oil but ran. £50? cant remember whats left on it tho... will have to check, think i used the alternator/starter etc on the 18rg
I'm not curse word, i just fell off my shoes
