Mot April 2013 tax end of Feb 2013
V5 present and have some reciepts paperwork etc, has two sets of genuine keys and remotes.
Slightly Modified:
Full stainless steel expensive exhaust cat back made by cobra/exhaustsuk
is quite loud and has a lovely deep exhaust note.
JWT S3R Cams picks up really well and does have a slightly lumpy idle which is inherient from these aftermarket cams.
Battery properly relocated to the boot with tray to give space for a Cold air intake if desired.
Air con removed to save weight and no extra belt/pulley running of the crank now has a smaller belt fitted direct to alternator from crank pulley.
New Battery,Cat and Manifold
Twin slim type front Coolant fans wired correctly.
Silicone Coolant hoses.
Front bumper is open mouthed and roof and mirrors are covered with black vinyl afaik there not hiding anything untoward and was fitted by previous owner.
Alpine Cd Player and original CD changer is in the boot.
Skyline Steering wheel and also have original airbag steering wheel.
No oil leaks, coolant leaks or steering leaks.
Interior is fairly clean and decent.
Good tread on tyres all round and matching front tyre brands.
good brakes all round with plenty of life left.
All electics working order.
Recently Serviced with 10W40 Fully Synthetic Oil, Oil Filter, Air Filter, Spark plugs and Leads.
Overall a not bad GT signs of touch up paint in places, apart from that the bodywork I would say is average for its age with signs of use, stone chips, small scuffs/scratches etc not scruffy in appearence but far from mint.
Fairly decent to drive as a slightly modified car as it is or maybe scope for a trackday/weekend car.
Scope to consider would be with a Cold air intake and a 4-2-1 manifold/dpipe setup and along with the cams already fitted I would say its possible to see around 195bhp maybe more.lt now has one.
Stick some coil overs or decent shock/springs setup on it and it would be a very good track or fast road setup.l will include these with the car.
The engine alone is worth more than asking price
07403277707
Slightly Modified:
07403277707
