marsie
Well i have done it again . I have bought a 1972 scimitar gte . It has been stood at least 4 years and the paintwork looks like its been applied with a steam cleaner. But its got potential Good points- solid chassis Good(ish) engine stainless exhausts working overdrive almost all electrics work!! Bad points- Paintwork sh*te interior needs fettling previous owner used offcuts of beige carpet glued in! needs bit of fibreglassing at rear end clutch slave cylinder leaking No mot so first job is to get an mot on it then i can do it as a rolling project. don't think it will need much to get through test, couple of suspension bushes and free brakes off Paul
Last Edit: Nov 26, 2013 19:38:44 GMT by marsie
Some people are like slinkies? They serve no real purpose in life but make you smile if you push them down the stairs!
1972 Scimitar GTe se5a
Excellent!
Currently: 1974 Beetle - Golf -
Previously: e38 735i, e34 525iSE, 1972 Beetle, 1991 Scirocco Scala, Morris Minor, 1983 Polo Breadvan, 1991 Mazda MX6
Great base to start with, shall have to subscribe to this!
'69 MG Midget | '94 200SX S13 RB25DET Project
nice! never realised the engines sat so far back in them. What glass work does it need ? I do glass work repairs for a living so curious
nice to see another scim
marsie
Thanks guys, definately one worth saving. Yep the front of the engine is behind the axle, almost mid engined . As for fibreglass work - there is a crack in the rear above the n/s rear tail light and a small crack in the nsr wheel arch( would eventually like to build some wide arches if i ever get confident enough to tackle it ) and a bit around the front indicator pods. Got to re-learn the dark art of fibreglassing Paul
Nice, must be hard to remove the lump or is it shell off. no dark art to glassing just making sure you don't follow the plonkers on youtube west systems do a good diy book
slot
Liking the start of project Cim Tar mate
Last Edit: Nov 4, 2012 22:14:22 GMT by slot
marsie
Nice, must be hard to remove the lump or is it shell off. no dark art to glassing just making sure you don't follow the plonkers on youtube west systems do a good diy book don't think so, once bonnet off gives good access and bar in front of engine is removable so should come out with box still on? will have a lookout for the west systems book
marsie
Liking the start of project Cim Tar mate The rest of the letters are in the glovebox . Found out that SCIMITAR is and anagram of I'M RACIST ;D Paul
1972 scimitar GTEChasR
@chasr
Club Retro Rides Member 170
I do like the earlier GTEs like this one . The Chrome suits them quite well. This should make for a great car once it is done. They also happen to look great when dropped a touch and put onto Revolutions .
Lovely...! I have always fancied a Scimitar and it is an itch I am going to have to scratch soon...!!! So, what are your plans for this old GTE?! Is it going to be standard or a bit on the tweaked side...? I shall be keeping a close eye on this one! Good luck sir
***GARAGE CURRENTLY EMPTY***
Ive got a 5a workshop manual for sale if your after one...4
Hello, over here too, Marsie !
Will you have to take the engine out? I got mine and gearbox out in one unit. It's a long reach in with a standard engine hoist. I had to lengthen the arm on mine to reach in far enough to the front of the engine. Even so I could only lift it up and forwards part way, then reposition to lift it more centrally.
I'm sure an extended hoist arm with an Essex and gearbox hanging on the end is not recommended by the hoist manufacturer!
marsie
hopefully wont have to pull engine just yet. But if i do i have a forklift truck and although it only lifts 2.5 tons i think i may just manage the essex
Excellent - I do like a Scimitar, especially a 5. ;D hopefully wont have to pull engine just yet. But if I do I have a forklift truck and although it only lifts 2.5 tons I think I may just manage the essex Sounds like a pretty close-run thing to me.
Last Edit: Nov 6, 2012 19:08:55 GMT by jrevillug
marsie
Found something today that said the SE5a was 1100kg, if thats the case when i take the engine out the rest will float up into the rafters ??
Smiler
Ooh, very nice. I have back burner plans for an SE5a. Though saying that I also have back burner plans for a Triumph 2500 saloon, a TR7, a Rover SD1 and a few others. But the Scimitar is one of the few I keep returning to.
If you don't mind me asking, how much did you pay for the car?
Last Edit: Nov 6, 2012 22:42:34 GMT by Smiler
marsie
Been stood at least 4 years but is solid underneath. Have ordered a load of goodies for it today from ebay. Nearly spent as much again
Last Edit: Nov 26, 2013 19:36:22 GMT by marsie
Smiler
Nov 10, 2012 20:50:10 GMT
£400??Blimey! Bargain! I hope I find one like that when the time comes.The only possible addition I would like would be a webasto roof.
