I spent all evening in the garage with the Dremel cutting the Front bumper to fit my Evo 2 with the big intercooler fitted.
the original plan was to buy a 2nd hand aftermarket bumper for it to allow me to use the larger intercooler for my mahoosive turbo conversion. This would set me back over £400.
2 broken cutting discs, about a metre of masking tape and some scrapes and grazes later, the std bumper now fits ok. The only down side is that the central "hole" isn't quite as deep or as tall as the new intercooler so I got to thinking about it and if I can modify the lower edge of the central aperture, I can maximise airflow to the whole intercooler. I want to do a proper job so was thinking about plastic welding as a way to get a nicer finish to the bumper rather than just cutting it. I would basically cut and shut the bottom edge by moving it down and fit the Evo 3 splitter I'll probably drill some holes along the top as theres a metal plate/bracket behind areas of the bumper for strength and I can't remove it all as thats where the brackets mount to.
Heres what it looks like with the std intercooler:
would plastic welding work?
Heres a chpped image showing what it could look like:
