think you will need a 5 speed from a 2.8 capri, I know someone selling one, incedentally one tip for the 5 speeds is to overfill the gearbox with oil as the 5th gear extension doesn't get much lube, and gets a bit hot in prolonged use, so I'm told. you'll need a shorter propshaft, and the splines on the clutch centre plate may be different. nitemaresracing is the cologne expert on here lovely coupe, BTW
Cheers Bodie.... and Doyle
Could you email me the contact details for the guy selling the box? I might have to speak to Mr Nightmareracing too...
your car is basicly a left hand drive cortina so same rules would apply. you will need a gearbox from either a 2.8 capri v6 sierra or granada and a cortina auto gearbox crossmember , prop should fit as long as its the 23 spline type you may also be able to use your bellhousing as it may be needed for clutch cable placement ,not to much trouble if you can't use it but if the cable goes in from the opposite side you would need to get a longer cable made up by sombody like speedy cables . not sure on the clutch but I would assume it would use the smae clutch as the 2.3 v6 which will be fine. if your going the change the box it would be a good time to upgrade to a 2.8 or 2.9 cologne both can still be found for next to nothing and its a straight swap insidently gearbox tip is a good one but don't put to much in or you will just blow the rear seal best thing i have found is to empty out the box of any old oil while its out and refill with ep75/90 and add a friction eliminator you wouldn't belive the abuse the whiney old box in my estate gets and its still hanging in ;D
Last Edit: Jan 8, 2007 23:51:49 GMT by Deleted
retro rides strikes again...Thanks Nightmares.... 64impala is a mate and we'll be helping the project along. Do you have a box and crossmember?
Thanks for this info guys - you are a kind lot.
Right, I guess I need me a Capri 5-spd. Any takers?
sierra XR4i will have the right box in it as well, supposed to be slightly stronger than the earlier 5 speeds.
don't know about stronger but it does have a longer 2nd gear i have a crossmember but my spare box will need to go in the estate soon you'll find out why at one of the shows but crossmembers yours if ya want it
will send you a phone number in the morning, its bruisercapri on here (his internet is borked ATM and has been for some months). he has a 5speed 2.8 capri 'box, and a 2.8 engine going cheap too if you feel inclined. I'll see what he wants for the 'box tonight. its in sudbury, suffolk
Excellent! Thanks for the x member Mr Nightmare - you're v kind. And by all means post a number (or text me on 07763 59787) for that engine/box bodie....
Excellent! Thanks for the x member Mr Nightmare - you're v kind. And by all means post a number (or text me on 07763 59787) for that engine/box bodie.... no worries mate don't want anything for it just pay the postage or pick it up from me or at a show your choice
How close to Lincolnshire are ya? I'm on the A1. If you aren't I'll pay for delivery!
my sister lives in old leake but i'm down in essex would have thought P&P would be about £7 ish at the most
64impala, just sent the number to you're messages box
Thanks for all your help Edd (BodieDoyle). I've been in touch with Christian and I'm arranging to fetch the 5-spd next week hopefully. We'll see if he twists my arm to take the whole 2.8 lump with me... ;-)
Ether
Now now Jonny, no engine swops...
bstardchild
Club RR Member Number: 71
Jan 12, 2007 11:29:07 GMT
will send you a phone number in the morning, its bruisercapri on here (his internet is borked ATM and has been for some months). he has a 5speed 2.8 capri 'box, and a 2.8 engine going cheap too if you feel inclined. I'll see what he wants for the 'box tonight. its in sudbury, suffolk Well ask him when you see him if he got the CD's?
Jan 12, 2007 19:22:59 GMT
no sweat, 64impala BC, yeah he got 'em, also PM coming your way
Jan 15, 2007 15:35:05 GMT
Still looking for a 5-spd from a V6 Cologne motor. Anyone?
