eurogranada
Sorry to hear about the starting problems. I agree with Sam that it should be something rather simple which should be solved rather easily with a few pieces of wire and a multi meter. i would ques it is a relay or the ignition lock which can be bypassed with a piece of wire. Peter I expect it to be something simple, but remember that this engine brought a 104 extra wirs with it... The whole starting system is PATS controlled etc. But my guess is a stuck starter or possibly a stuck relay.
eurogranada
Very faintly similar yes... I've got it's owner on facebook. The colour is much darker than mine, it doesn't have a black interior, and the wheels are solid black also no accents like my black stripings. This car is indeed, as you say, nowhere near the condition mine is in. It's got a (currently) non runner BOA engine, needs body work, got damaged between sale and delivery so relisted I believe... But the price is also a lot lower than mine would command. And the owner was at least just as fond of the car as I am of mine...and that I always hold in high regard.
eurogranada
Feb 13, 2018 10:08:27 GMT
Check that the starter is getting power first, but I would guess a new starter solves the issue. Sounds very much like my failing starter this summer. Ignition lock is also suspect, so check for power in/out of it too. Gustaf Yes starter may well be, or a relay of sorts. I even suspected the ignition lock. But upon ignition, a lot of other systems do get power. I've got some things to check. And yes, battery is one, power to starter is two, as lack of that would lead to relays as no. three check and the ignition lock as no. four I think...
Feb 13, 2018 10:17:26 GMT
If you can reach easily I would start by shorting between the main power feed on the starter to the solenoid connection (a screwdriver with an insulated handle works well. If the starter spins and engages it tells you the starter and battery is fine and the problem is the feed to the solenoid. If it doesn't spin then its the starter or main feed to the starter. A nice quick test that can tell you a lot. Obv just make sure its not in gear / parking brake is on etc.
The Doctor
Club RR Member Number: 48
Feb 13, 2018 18:00:00 GMT
Maybe the gearbox switch? So it doesn't know it's in Neutral or Park?
eurogranada
Feb 14, 2018 13:26:41 GMT
Maybe the gearbox switch? So it doesn't know it's in Neutral or Park? I discounted that by putting it in several positions, but no dice. It's always the first thing I check when not starting. In theory it could possibly have become misadjusted from the bolt undoing itself a bit but it's not my most likely explanation.
eurogranada
Feb 16, 2018 16:40:45 GMT
Well today I made some time to get to the bottom of my non starter Granada.
I pushed the car to the limit of it not rolling out and put the hand brake on. I hooked the spare battery up for support of the one that was in it. Next I tried jumping the starter from the positive to activating contact. I was a bit apprehensive to do so but it went fine. The starter turned so it wasn't dead! I checked all relays for operation and they seemed fine as well. They all clicked. Spurred on by this I set the ignition switch to on and had pats recognise the key and tried jumping the starter again. The engine caught and ran! After cut of, it would not restart by key. I had also checked the neutral safety switch, but that seemed fine as well. And when it ran it proved that the gear selection was spot on. It went in reverse and drive.
So I guess the problem is in the ignition switch or the wire that feeds the starter.
I consider this good news! The car is movable... the bad thing is that access to the back of the ignition switch is very limited! Either the binnacle needs removed or the entire console and bottom plate of the dashboard need to come away. Both not my favourite jobs. But as the binnacle has to come out anyway for the two barely operating gauges this will be my first approach. When I get the time that is.
My look underneath has shown I really need to suck some atf out of the box. It has made a mess of my bottom and exhaust.
So still some stuff to do...
Feb 16, 2018 19:03:37 GMT
Good to hear you are getting there to solve the problem
Feb 16, 2018 19:53:45 GMT
Does the ignition switch directly the starter or via a relay, If a relay try bridging the power wire to the solenoid wire or replacing the relay to rule out the relay (they can still click and not work).
eurogranada
Well the weather has kept me from doing any further research on the starting issue. Also last time I started it with the screwdriver, it smoked from under the hood. A little alarming at first but it came from down low, not from where the wiring sits. I guess I'm burning off the gearbox oil that has clung and burned to the exhaust... So I've decided what needs doing pretty urgently is draining some of the box fluid by means of a vacuum pump. I'll try and borrow one for the weekend or next week from a mate who onws one. Next I'll have to drive it home and douse the engine, box and exhaust system in degreaser before washing it off with a pressure washer. I kinda hate to do that because of the electronics on the engine, but the engine bay is diiiiiiirty from all the months of work and the accidents like the gearbox oil cooler hose splitting etc. and the exhaust well it feels sort of like its wrapped in cotton candy that got too hot... With the car out in the light I will once again try and diagnose the starting issue. I'm going to see if I can swap out the different relays before doing anything else as I should have spares from my donor car. I'm having a hard time grasping how one can start a car with the key, put it away after a drive and not being able to start it with the key right after... My mind won't let me believe that this is a loose wire in the dash area. Possibly more feasable in my mind is a broken ignition switch, but that should be testable by bridging the responsible wires right behind the switch. If the thing turns over it must be the switch. I'm currently trying to avoid the dreaded dash removal again... Although next on the list has to be the fuel sender/gauge reading and the temp reading. I hate not having those. Got to be simple yet I haven't gotten them to work. I might ask SamJ once more if I can't get them to work. It's the last of the technical issues. After this there is only the issue of the cubbies to be made, but I'll hold off on that till I've moved house.
vulgalour
Club RR Member Number: 146
Mar 15, 2018 13:15:17 GMT
This sounds very frustrating, I wish I could offer you more than moral support. You've managed to fix lots of other things so there's no doubt you'll get to the bottom of this one. It's bound to be something daft too, these sorts of things always seem to be.
eurogranada
Mar 19, 2018 11:18:52 GMT
This sounds very frustrating, I wish I could offer you more than moral support. You've managed to fix lots of other things so there's no doubt you'll get to the bottom of this one. It's bound to be something daft too, these sorts of things always seem to be. The frustrating thing is the cold keeping me from doing anything.... I guess a good few hours would at least solve the overfilled box, and the cleaning of the mess that left as well as basic troubleshooting on the starting issue (swapping relays). But I need a bit of a nicer day to do this. And time is pressing as I am about to be forced into overtime at work to keep my agenda going and to spend a huge amount of time on all the moving related stuff and I also just want to be able to enjoy the car this year. A lot more than last year. Also because this tends to balance out some of the harder stuff in life.
Mar 19, 2018 12:52:37 GMT
I went into my garage for the first time in weeks the other day, and the thermometer on the wall said 2c, too cold to work... I can wrap up warm, but everything you touch is just too cold to handle as far as I am concerned. I'm over in the UK this weekend but weekend after, 31st / 1st, I'm around if you want a hand with things
eurogranada
Mar 19, 2018 13:56:00 GMT
I went into my garage for the first time in weeks the other day, and the thermometer on the wall said 2c, too cold to work... I can wrap up warm, but everything you touch is just too cold to handle as far as I am concerned. I'm over in the UK this weekend but weekend after, 31st / 1st, I'm around if you want a hand with things My sentiments exactly...add to that that I have no power at the box garage, so I need to bring the car home to do this stuff. Home currently still means working out in the open so again, cold! Thanks, I'll see what I can get done myself before taking up your equally valuable time. But rest assured, I won't hesitate to ask if (or when) I get stuck! Currently on the hunt for a pump to suck some gearbox oil from the box...
Mar 19, 2018 21:33:22 GMT
But the big move is not that far away is it? Hope i didn't miss any news regarding your new house
eurogranada
But the big move is not that far away is it? Hope i didn't miss any news regarding your new house I don't think you missed anything. I think there was little to tell after the initial contracts were signed and the waiting periods started on all the different clauses that were in the contracts. As of last Thursday though, all clauses have been met and therefore both deals are final: our new house has finally got the official "sold" stamp and our current home received the same a day later. Now it's a final wait of another 40 or so days until we get the key of the new place and 65 days until we have to hand over the keys to our current home. In the mean time we've now got permission from the current owners of our new house to come over and measure each room and inspect the house with our contractor to see what needs doing and when. That took some doing though... We thought we had a decent size budget, but we're easily 8k light so.... we'll have to see what needs doing and what wants doing... Things like a 10k kitchen, a 3.5K garden house (shed with extended roof to sit under), new sectional garage door, exterior painting, interior foors, walls that need the builder's equivalent of "a skim of filler", a wall to wall closet system (as the new place lacks one room compared to the current house).... etc. etc. It's in my nature I know, but I have to admit I'm a bit scared of the month of may. Double living costs, expenses to get the renovation going that I need to front before getting it back out of the build budget and before getting the compensation that we're due after our house is transferred to the new owner. It'll all work out in the end, but I'll be happy when July comes along and all our monthly payments have settled to their definitive levels. And I've not even gone into the details of organising the actual move and reno... Anyway, this means that I'd like to get the Granada issues mostly solved in the coming month...before all of the above starts. The goal is to keep the Granada's rented home on till July. It means I can move stuff in and out of my new home garage during the move/reno. Worst case, the Granada issues will have to wait till after the move, but that to me would mean that the best time of year is again lost as far as enjoyment goes...
mk2cossie
Club RR Member Number: 77
Sounds like it is all go for you eurogranada Glad that the wheels are in motion for your house move though, will be good to get the car next door to where you live finally I bet
eurogranada
Well, with only a minute here, a minute there and for the moment no budget, I’m frustrated with the Granada!
I have a beautiful, fun to drive car in the garage yet I can’t actually drive it.
I’ve been able to swap out the relays, working in a cramped area in the near dark and off course they were not the problem...
I know it’s just a little thing, but I'm frustrated that without doing one job I can’t get the car moved to a location where there is light and room to actually do proper diagnosing. And then the needed under car cleaning.
Sorry to moan a bit but this is just how I feel right now. Working overtime at work, fixing a leaky toilet drain at home (required full floor removal) and prepping for a house move that knew it’s own complications as the current owner does not share our sense of honesty...and it’s hard to feel positive...
Alex if it's any consolation at all I am in the same situation but for different reasons - I have diary full of clients work and Sharon is on my back now she has a stunning kitchen and wants the utility (which is a bombshell) to match along with the garden sorting this year, also the private lane to the house resurfacing but no time to sort my own cars / projects - there is of course a master plan but it would be nice if the 'light at the end of tunnel' was not just a bloke with a torch bringing me yet more work - not complaining of course it's nice luxury to have knowing that you don't have to worry about where the work comes from and that you are not going to run out of it anytime soon - we will all get there 'one day' - hope it all goes well for you - Chris
vulgalour
Apr 14, 2018 18:30:12 GMT
We're all rooting for you, you'll get there! Might seem pretty bloody miserable right now, but it'll come right in the end.
