Allo, Just sorting the aux belt out on my Zetec Rwd. Its been converted to the correct water pump but which way should it turn?? Clockwise or Anti-clockwise???
I'm just an average man with exceptional hair.
Escort water pump, yes, rather than the Mondeo pump? IIRC, the Mondy pump runs off the back of the belt - without grooves - and thus spins anti-clockwise, while the Escort pump runs off the 'front' of the belt - with grooves - and spins clockwise.
I could be wrong though.
Well its got the non-grooved pulley on it. But was told its got the escort w/p fitted. Thats a bit of a blonde moment mind, bit obvious now you've said if its got grooves its clockwise...non-grooved anti clockwise.
Can you remove the pump and check out the vanes to see which direction they are biased ?
Paul H
Hmm. Fairly sure that the Mondeo had the smooth pulley and the Escort the grooved: in the Escort setup the belt just runs around the outside of the crank, pump and alt, while the Mondeo has a serpentine routing.
Just looked outside for you handy having both cars escort grooved , mondeo smooth.
Dan
Cheers Dan. Will measure it up tomorrow and get onto the local parts supplier.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
yes as said you need escort/fiesta pump and the grooved pulley,.
facebook: rodney dean / rd transport
escort of fezza pump, long as u use a triangle belt so it all goes the right way!
cars: orion 1600 i ghia mk2 orion 2.2 vtec ghia mk1
