Sept 27, 2012 21:07:18 GMT
Chaps
This may be a stupid question but here goes.
I bought a car from a dealer who had it MOTd. To me the hand break is wibblepoo and wouldnt keep the car from rolling on even the slightest of hills.
But because its an auto, whilst in park its all good...
So is a hand brake tested on an auto?
Cheers
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
Sept 27, 2012 21:17:02 GMT
Yes, handbrake is still tested on autos. You need a minimum of 16% efficiency to pass (25% on cars with single circuit brakes).
(16% is roughly the same as holding on a 1 in 6 slope)
Sept 27, 2012 21:37:09 GMT
thanks mate - does it need to be within so many clicks? I yank mine all the way up and it has very little hold..
Sept 27, 2012 21:38:49 GMT
This brake efficiency percentage - is it basically horizontal force of the brakes VS overall weight, or weight over that axle? Is the weight measured by the brake machine or off a chart? I've had cars with functionally real curse word handbrakes pass with flying colours, and cars with really good ones fail. My Lupo had a cracking handbrake, new cables and mechs and pads all adjusted to VW specs from ELSA and it failed on insufficient reserve travel" but it would lock the back wheels up from speed at 4 clicks
Last Edit: Sept 27, 2012 21:44:34 GMT by cobblers
Sept 27, 2012 21:49:14 GMT
Percentage is derived from brake force at wheels divided by vehicle weight. Some automated test lanes weigh the car, the computer provides a value from VSI for most modern stuff, kerb weight from the VIN is also acceptable. If weight is unknown you test for efficiency with a decelerometer (tapley meter) instead.
There is no requirement for the lever to operate in a certain number of clicks as long as there is reserve travel, handbrake should only be applied to the point where a pass is achieved.
Oh also, there must not be side play in the lever bad enough to make the lever slip off the ratchet.
Sept 28, 2012 7:21:54 GMT
if its that bad -contact VOSA & get them to check it. That way you find any other 'issues' that were passed -and strengthen your hand against the vendor -either as a return ,or compensation.
bl1300
Sept 28, 2012 7:27:25 GMT
a 16% effieciency handbrake in the real world feels really curse word! My van gets 35% on the tapley at 7 clicks. I had to shorten the Triumphs handbrake cable as all though I could get 25% on it the lever ran out of reserve travel.
Current fleet.
